hey guys,
I have been trying to upgrade my Ryzentosh from 10.15.7 to 11 but I think I am doing something wrong in some config due to that I am unable to boot installer
I have created completely new EFI for new version and also did OpenCore Sanity check config.plist file
but at the time when I boot from installer media I am getting some this like this :
after this I select option 2 I am stuck at this point and after few mins system automatically reboots
or if I select option 3 which is auto downloaded bigsur update in my system stuck at this point
Sys config also attached EFI folder
Processor - AMD Ryzen 3600
MoBo - MSI B450 Bazooka Plus
RAM - 16GB HyperX
GPU - RX580 8GB
just have look if you guys can help me out to know at where I am doing wrong or any config.plist correction require.
it will be helpful if I can install 12.0 Monterey instead of 11.x
RAM - 16GB HyperX
GPU - RX580 8GB
