Dear all.
Thanks to coderynx a patch for Luminar v.4.3. is now available. It is tested and works great on Catalina 10.15.7, running on AMD.
The patch can be run one line at a time in Command:
Thanks a lot to the community this magnificent work.
Kindest regards
FreedomDK
sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x6A\x00|\x90\x90\x90\x90\x56\xE8\x3A\x00|sg' '/Applications/Luminar 4.app/Contents/Frameworks/MPCore.framework/Versions/A/Frameworks/libtbb.dylib'sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x4A\x00|\x90\x90\x90\x90\x56\xE8\x1A\x00|sg' '/Applications/Luminar 4.app/Contents/Frameworks/MPCore.framework/Versions/A/Frameworks/libtbb.dylib'sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x6A\x00|\x90\x90\x90\x90\x56\xE8\x3A\x00|sg' '/Applications/Luminar 4.app/Contents/Frameworks/MPCore.framework/Versions/A/Frameworks/libtbbmalloc.dylib'sudo perl -i -pe 's|\x90\x90\x90\x90\x56\xE8\x4A\x00|\x90\x90\x90\x90\x56\xE8\x1A\x00|sg' '/Applications/Luminar 4.app/Contents/Frameworks/MPCore.framework/Versions/A/Frameworks/libtbbmalloc.dylib'Thanks a lot to the community this magnificent work.
Kindest regards
FreedomDK
