Help 3950x with 570 motherboard
sac23
Hello anyone get big slur booted on 3950x with a 570 motherboard thank u guys much appreciated I used a efi folder I found but I get issues here is a pic of issue
sac23
so got this booted with a different efi folder but no network
AudioGod
List the Full system spec please including make and models And I will see what I can do for you?
sac23
thank u much appreciated
Ryzen 9 3950x
asus 570x
64 gigs of ram
Nvida gforce gtx 770
cooling corsair h100
so only thing is is a little laggy
and main thing is no internet
it also has a popup that says your memory is more than it suppost to be
here is the efi i used to boot thanks to
SubjectIV for it​
thank u much appreciated for your help
AudioGod
Ryzen 9 3950x
asus 570x
64 gigs of ram
SubjectIV for it​
What asus X570 is it? What’s it’s model number?
sac23
aorus master X570
x570
AudioGod
aorus master X570
x570
Use my EFI from here
and add the following kext to make both Ethernet ports work for you.
sac23
thank u i will try this tonight
sac23
ok so i couldn't wait so i went and tried it all I can say is THANK U so still wifi is broken but the wired is working perfect thank u so much
is there somewhere i can donate to u for your help please let me know thank u again
AudioGod
For your WiFi and Bluetooth add these kexts.
WiFi - https://github.com/OpenIntelWireles...tItlwm-Big_Sur-v2.0.0-DEBUG-alpha-5eb3a17.zip
Bluetooth - https://github.com/OpenIntelWireles...re/releases/download/1.1.3/IntelBluetooth.zip
You can donate to this forum using the the Donate button at the top of the page :)
sac23
perfect thank u just donated as well i will try those kext tonight thank u for everything
also side question u think u can help me get big sur on intel based pc i have at work
intel i7 8700K coffee lake
asustek rog maximus X hero wifi-ac
ddr4 24 gig ram
nvidia gforce gtx 770
just wondering sorry if this is wrong place to ask
just wondering if it will work thank u again
@sac23 Intel setup is the same as AMD minus the kernel patches. The dortania guide will work just fine :D
sac23
hi shanee i hope all is well
thank u sir but i sorry i cant find that guide
AudioGod
sac23
thank u much appreciated that i might not be able to do loll was hoping for a efi file i can download u guys are awesome thank u
sac23
Ok so please looks like need help on couple more issues no sound at all but Bluetooth works as in it connects to airpods but it still shows as red but u can hear sound from airpods and still no wifi after those kext
sac23
Fixed sound :)
just wifi and can't sign into the cloud i get an icloud_unsupported_device
thank u again guys for all your help and sorry for so many issues
sac23
Hi yes I did add that kext to the kext folder for wifi still nothing as for the en0 where can I check that because it only shows the ip address and so on
AudioGod
Use hackintool, it will show you if it’s set to internal but It should be anyway tbh.
Have you entered smbios details for 7,1??
if not then that’s what you need to do
