Mymulan's GIGABYTE Aorus master Rev 1.2 with TITAN RIDGE 1.0
Mymlan
24
16
i9-9900K
To make Strong WORK STAION for making movie, photos,
I made a new ryzentosh as below:
MB: GIGABYTE Aorus Master Rev 1.2
CPU: Ryzen 5950x
CPU Cooler: Corsair iCUE H150i RGB PRO XT
RAM: 64MB Patriot Memory Viper4 Series DDR4 3200MHz PC4-25600 16GB x 2, TEAM GROUP VULCAN DDR4 3200MHz 16GB x2
Graphic: PowerColor Red Devil AMD Radeon RX 6900XT 16GB GDDR6 AXRX 6900XT 16GBD6-3DHE/OC
NVME: M.2 2280 / WD BLACK SN750 NVMe 500GB for Mac
Silicon Power 512GB NVMe M.2 PCIe Gen3x4 2280 TLC for WIN
OWC Express 4M2,TOPMORE 2TB M.2 2280 PCle SSD TLC x 4 as RAID 0 via TB3
Thunderbolt3 Card: GIGABYTE GC-Titan Ridge v1.0, firmware nvm33 Flashed, connecting pin3 and pin5, LIKE THIS)
CASE: Thermaltake Versa H26
I will replace from H26 to Dune Pro next month.
PSU: SilverStone STRIDER PLATINUM 1200W SST-ST1200-PTS
Wifi: Oley BCM943224PCIEBT2 (installed at PCIEX1, No connecting BT to USB2 Header)
Bluetooth: AX200 (Built-in)
Audio Interface: Apogee Duet to use microphone
OS: Big Sur 11.5 Beta(20G5023d), Windows 10 Pro
Bootloader: OpenCore 0.6.9
SMBios MacPro7,1
ACPI:
All files are included [If (_OSI ("Darwin"))..] to boot Windows 10.
SSDT-TB3-HackinDROM mod .aml ( Based on GIGABYTE B550 Vision D , pay attention it's not GC-Titan Ridge v1)
SSDT-XHC.aml to fix USB port
SSDT-SBUS-MCHC.aml ( I'm not sure)
SSDT-EC-USBX-AMD.aml
SSDT-NVME.aml
SSDT-PLUG.aml
SSDT-SBRG.aml
Kexts:
AGPMInjector.kext (Customized for RX 6900 XT)
RestrictEvents.kext (for MacPro 7,1, fix Memory Slot, fix CPU name)
LucyRTL8125Ethernet.kext
NVMeFix.kext
VirtualSMC.kext
AppleALC.kext
Lilu.kext
WhateverGreen.kext
USBMap.kext
AMDRyzenCPUPowerManagement.kext
IntelBluetoothInjector.kext
IntelBluetoothFirmware.kext
SMCAMDProcessor.kext
SmallTreeIntel82576.kext
ThunderboltReset.kext
AppleMCEReporterDisabler.kext
What Works:
Both Ethernet ports
Bt/Wifi
AirDrop
Handoff
Thunderbolt3 Hot plug? 4M2 keeps connecting after cold boot, after wake.
Amazon Prime Video via Safari
Apple Watch Unlock
Microphone works via Apogee Duet
Windows can boot from Opencore
What doesn't work:
Side Car
Internal Mic input
BIOS settings:
Firmware Version is F33j.
Extreme Memory Profile (X.M.P.) -> profile 1
Wake on LAN -> Disabled
Above 4G Decording -> Disabled (When Enabled, got ACPI error and stuck)
PCIEX16 Bifurcation -> Auto
Resize bar -> Disabled
Titan Ridge Enabled, No Security
AMD Overclocking -> PBO Enabled
I often use these Apps:
Capture One 21 Ver.14.1.0.220 (Beta doesn't work with RX 6900 XT ,got Noise when exported JPEG Files)
Davinci Resolve Studio 17.2 ( no need patch)
Illustrator 25.2.0 (patched, I forgot details)
Affinity Photo 1.9.0 instead of Photoshop
About Thunderbolt 3:
Before making this build, I used Z390 Asrock Phantom Gaming6, Intel i9-9900K, RADEON VII with Titan Ridge.
Then I flashed TR firmware in accordance with this .
It's installed at PCIEX4 (Bottom of this MB slot).
Now I noticed it doesn't work on X570 because the Device PATH is incorrect.
I learned a lot through trial and error, finally I made custom aml file.
OWC Express 4M2 completely works.
I have 40Gb/sec.
I don't connect TR to THB_C Header.
Wifi/Bluetooth Card:
I installed at PCIEX1, don't connect Bluetooth to USB2/0 Header.
Because I don't try disconnecting internal wifi 6 /BT AX200 and add DeviceProperties -> Delete -> Wifi 6 AX200.
If I know how to disable Bluetooth USB port, then I will connect Oley BCM943224PCIEBT2 to USB2.0 header.
Reactions: AMDPUSH
Erm,
Is there something you want to say about where you got most Your SSDTs from fella?
Also You are fixing EC with one SSDT and then fixing it all over again with a second one.
Do you know what two SSDTs I’m referring too?
Curious why you did not connect the cable to the TB£ header and used the looped cable like we do on the CMP
Reactions: AudioGod
Erm,
Hi, AudioGod,
Of course I follow your SSDTs,
but I don't understand well.
I think I don't feel the need, just I want working station.
Thanks.
And I am sorry for my bad english.
Reactions: slehc84
Hi, AudioGod,
Thanks.
LoL Don’t worry about it bud, It’s no problem.
Can I help correct the EFI for you?
If you want a hand then just let me know?
P.s Your English is fine 👍
Several years ago,
There were a lot of ways to fix Hot Plug.
On me, just tried cMP's way, then it works.
There is no deep meaning.
Just I noticed Titan Ridge works without THB_C header.
Thanks.
Oh, Thank you so much for your kindness!
I watched some your posts, you are good person! ( or cat? )
So now I don't feel problem, if I notice problem,
I will ask you 😍
I will ask you 😍
I’m a Naughty Cat of course, Meowwwwwww 😹
I see a good few things that should be changed in your EFI, When I am free in a few hours a will give you some pointers buddy. 👍
  • Love
Reactions: Mymlan
Nice & lovely kitty🐈
Please give me improved ideas, my dear lord❤️
I have get to go my work,
Thank you!!
Several years ago,
Thanks.
Ok :) . I should put my TR card in again and see how it goes, but now I just use the USB C port into my TB3 hub
Reactions: Mymlan
CPU: Ryzen 5950x
SMBios MacPro7,1
ACPI:
SSDT-NVME.aml
SSDT-PLUG.aml
SSDT-SBRG.aml
Kexts:
NVMeFix.kext
VirtualSMC.kext
AppleALC.kext
Lilu.kext
WhateverGreen.kext
USBMap.kext
What Works:
Both Ethernet ports
Bt/Wifi
AirDrop
Handoff
Apple Watch Unlock
What doesn't work:
Side Car
Internal Mic input
BIOS settings:
I have 40Gb/sec.
Hi, are you sure you will really have a DunePro case, seems there 's no store where they're available
Hi AMDPUSH,
I have ordered since 2019 that started the project.
So I will have this month.
Thank you.
Reactions: AMDPUSH
Hi AMDPUSH,
Thank you.
send me a picure as you ll made it
Reactions: Mymlan
Dear AMD PUSH.
Sorry, I'm late.
Here's my EFI.
Note:
I changed wifi card from Intel AX200 to bcm94360ng m.2,
Re-sizebar Enabled, Above 4G Decoding Enabled on BIOS setting,
due to OPENCORE 0.7.5.
Thanks.
Reactions: AMDPUSH
Thank you very much !
Can i put just the SSDT shutdown fix in my EFI and it will work ?
Why and What special trick who made for your GPU ?
and what about the Dune case ?!
If you get reboot after shutdown,
watch this:
https://dortania.github.io/OpenCore-Post-Install/usb/misc/shutdown.html
My EFI has also "FixShutdown-USB-SSDT.aml" in ACPI Folder.
GPU trick means for windows, dual boot.
If no, you keep Re-Sizebar disabled, and Above 4G Decoding disabled,
and you add your Arguments "npci = 0x2000".
Dune Case!!
Still no get it!
Maybe Dune Case doesn't come...
  • Haha
Reactions: AMDPUSH
Thank you
I put the FixShutdown-USB-SSDT.aml in my EFI and adjust my config list with it, but it's not work.
I have a Antelope zengo USB audio interface wich use the power supply thru the mobo, i think why i get this restart.
Anyway thank you.
They (Dune Case ) give you your money back ?
Thank you
Anyway thank you.
I use Apogee Duet with external power supply, now completely works.
Dune Case team doesn’t seems to give my money back, I think.
I don’t trust them at all.
  • Haha
Reactions: AMDPUSH
I have a good news. I can switch on my UAD sattelite octo TB3 even after i have booted. seems to be "hotplug"
I have a Titan Ridge v2 on big sur 11.6.1 with OC 074
Reactions: Mymlan
It’s good information!
I use Apogee for Vinyl Records to rip🎸
It’s My old audio interface, but enough to me.
Reactions: AMDPUSH
