AMD Navi 10 and Navi 21/22 & 23 cards are the AMD 5000-Series and AMD 6000-Series discrete GPUs respectively.Can you explain a little about AMD "Navi"? Or post a link, please.
It would be better to recreate your installation USB key "" sudo /Applications/Install\ macOS\ Sonoma.app/Contents/Resources/createinstallmedia --volume /Volumes/MyVolume "" with real Mac. Please connect your keyboard, mouse and all your USB key to USB 2 if possible. Unplug the internet cable if possible. Unplug all other devices not necessary for starting.
Your OpenCore Log contains the following errors:
00:000 00:000 AAPL: #[EB.H.IS|!] Err(0xE) <- RT.GV boot-signature 7C436110-AB2A-4BBB-A880-FE41995C9F82
00:067 00:067 AAPL: #[EB.H.IS|!] Err(0xE) <- RT.GV boot-image-key 7C436110-AB2A-4BBB-A880-FE41995C9F82
00:437 00:102 AAPL: #[EB.CFG.DEV|!] Err(0xE) <- RT.GV booter-strict-xmlparser 7C436110-AB2A-4BBB-A880-FE41995C9F82
01:276 00:057 AAPL: #[EB|CFG:ARG] force-error 0x0000000000000000 (0x0000000000000000 & 0x0000000000000000) default
02:193 00:058 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.GV boot-signature 7C436110-AB2A-4BBB-A880-FE41995C9F82
02:353 00:057 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.GV boot-image-key 7C436110-AB2A-4BBB-A880-FE41995C9F82
02:466 00:056 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.GV boot-image 7C436110-AB2A-4BBB-A880-FE41995C9F82
02:522 00:056 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.SV- boot-signature 7C436110-AB2A-4BBB-A880-FE41995C9F82
02:610 00:087 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.SV- boot-image-key 7C436110-AB2A-4BBB-A880-FE41995C9F82
02:669 00:059 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.SV- boot-image 7C436110-AB2A-4BBB-A880-FE41995C9F82
03:213 00:086 AAPL: #[EB.LD.OFS|OPEN!] Err(0xE) <"\\F702F2D9-DBD8-3807-BF8D-5376D26EB951\\System\\Library\\CoreServices\\com.apple.Boot.plist">
03:272 00:059 AAPL: #[EB.OPT.LXF|LF!] Err(0xE)
04:313 00:056 AAPL: #[EB.OPT.RKS|!] Err(0xE) <- BS.LocP EDB4A040-6D8A-11EC-8FAD-3E22FB93ADCF
04:515 00:057 AAPL: #[EB.CS.CSKSD|!] Err(0xE) <- RT.GV boot-info-payload 8D63D4FE-BD3C-4AAD-881D-86FD974BC1DF
04:855 00:056 AAPL: #[EB.FS.AGSVH|!] Err(0xE) <- BS.LocHB 59D76AE4-37E3-55A7-B460-EF13D46E6020
05:187 00:058 AAPL: #[EB.WL.PWLFNV|!] Err(0xE) <- RT.GV wake-failure 7C436110-AB2A-4BBB-A880-FE41995C9F82
05:245 00:058 AAPL: #[EB.WL.DT|!] Err(0xE) <- EB.WL.PWLFNV
05:464 00:057 AAPL: #[EB.LD.OFS|OPEN!] Err(0xE) <"boot\\System\\Library\\KernelCollections\\BootKernelExtensions.kc.development">
Replace your EFI with EFI the here : https://drive.google.com/file/d/18js8931VdCSG8UYE6yEaa-gMR5W1zHOq/view?usp=sharing
I have adapted efi according to the errors here : View attachment 13690 https://drive.google.com/file/d/18js8931VdCSG8UYE6yEaa-gMR5W1zHOq/view?usp=sharing
If that doesn't work, please post your OpenCore log in ATTACH FILES
And if your problem is resolved, please specify where the problem was. I would appreciate.
With screen printing it would be even better
Message for ADMIN. Please, want to increase the upload limit in your .htaccess file or directly in your server configuration to allow sending files larger than 70 MB. It is impossible to send EFI 65 MB for me.
Excuse me. I was wrong, the EFI file settings were for on 8 core. It's corrected.
Please download efi file for 16 core on the same link in the last message or here : https://drive.google.com/file/d/1bx5NRGThfQjDRjEweWmLgnBAhqMDZZYh/view?usp=sharing
I came back from work.
I removed the code not related to the installation and did a new install.
How wonderful. It is working well.
The Bios settings on the motherboard (Asrock b650e pg-itx wifi) are the defaults and nothing has been tampered with.
I will now check the wifi, bluetooth, etc.
Anyway, it's great. My sincere thanks to you.
If everything works well (sound, network, bluetooth, wifi, graphics card) and you only have the standby problem. You are in possession of a new valid configuration for hackintosh (ryzentosh).
All my congratulations !
All that remains is to clean kext which you don't need and install the EFI file on the hard drive.
Can you download Novabench here: "" https://novabench.com/download '"" make a printscreen with test and post it here plis ?
For your standby problem. I'll respond tomorrow, but it's a minor problem and I'm sure we'll be able to resolve it.
Have you mapped your USB ports?
Having a misconfigured or not having a custom USB ports configuration (kext) at all, is a common cause for Sleep/Wake/Reboot and Bluetooth issues in macOS.
See this link for USB mapping in macOS.
Follow the manual pathway in the guide.
Try putting the DSDT files here as an attachment in the ACPI EFI\OC\ACPI folder with OCAuxiliaryTools opened in advance, so that it is taken into account.
For USBmap
Just watch the video I posted here above. Seen with even no need to understand the language. There is a maximum of 30 minutes if everything goes well. And you can build it under Windows. here -> : USBmap video Youtube
For a computer to restart on its own it can have several reactions.
What is your maximum CPU and GPU temperature setting in bios ?
Did you not put too much thermal paste on the processor ?
Look in device manager under Windows to see if there is a faulty device.
Do you have a hypersensitive mouse or keyboard key ?
Under Windows download CoreTemps here ->: https://www.alcpu.com/CoreTemp/
Under Windows download CPU-Z here ->: https://www.cpuid.com/downloads/cpu-z/cpu-z_2.09-en.exe
And started both, trigger CPU stres(benchmark) with CPU-Z and monitor temperature with CoreTemps to see any possible anomaly.
1: Your computer has a virus (I don't think so).
2: Update set to an automatic restart. (configure update to manual)
3: The most likely possibility is a hardware failure or poor GPU or CPU temperature indicator. If your Mac doesn't understand how to handle a certain device and it receives the wrong data that it doesn't understand to prevent any damage to it the hardware has no other option than to stop your machine. The same thing happens in the case if macOS cannot know the temperature of certain materials then it stops the machine to prevent any possible damage. In this case it records any errors in a dedicated log. What is strange is that it restarts normally it should shut down the machine. I suggest you first download and install Stats software to see if you can view the temperature of your CPU, GPU, hard drive and RAM.
here ->: https://download.macupdate.com/app/mac/62638/stats/download
4: You said in the dialog above that you left the bios configuration as default. I don't think this is a good solution. I can understand that you don't want to touch bios too much but you can very well save your current configuration profile and create another dedicated profile for your hakintosh configuration. And it is always possible to return to default configuration. For example if bios is configured to not allow the system to manage fan speed, his can create a hardware conflict between bios and operating system.
5: It is possible that it is your bios which triggers at restart. That would be more logical because bios when it reports a problem it restarts. One more reason for properly configure your bios.
For the sleep problem.
macOS Sonoma sleep here -> : https://www.youtube.com/results?search_query=macOS+sonoma+sleep+shutdown
The question is, during sleep macOS not detect mouse movement or key presses keyboard to wake up. It would be wise to disable the selective USB door suspend in the bios.
Is your keyboard configured correctly ? here ->: https://www.youtube.com/results?search_query=Use+a+Windows+keyboard+with+a+Mac
Try using another keyboard. We never know.
I forgot to tell you that after each EFI file replacement, it is necessary to Resset NVRAM.
I modified your EFI a little, try it. In "ATTACH FILES"
Maybe it could help you more in your native language. ⇾: https://www.youtube.com/@user-ro1tw7ke5y
I didn't understand what he said, based on the image, it's the right explanation.
The difference is that it uses "clover" and you open-core. So, you must place your ""USBMap.kext"" in the ""EFI\OC\Kexts\"" folder and replace the old one if it has it.
And here.
Can you take photos and provide a more detailed description, please... ?
