You are the best!! Thanks.Use this. All X570 boards are the same for XHC.
Hi Gopal334,
Would you be able to post your EFI folder please?
I've got GB X570 I AORUS Pro Wifi (rev 1.0) and trying to install latest MAC OSX on it.
I'm fresh to hackintosh on AMD and so far no luck with OC bootloader.
Cheers,
F
You may get some help from the experts @discord.Hi Gopal334,
Thanks for the folder it was very helpful. I did manage to get my boot USB working and now getting the Cartalina to install.
Not sure if this is the right place to talk about what happens next
I'm hitting some issue after reboot. After installation I'm booting second time from USB to load the installer on the SSD. It starts booting gets into the apple icon with the bar in graphics mode then it crashes with TRACE in the LOG - Installer Log 6-May-2020_2.log.zip
I've also attached my EFI folder if someone can suggest what to change to get it working.
Thanks in advance.
F_ender
Good Luck. Hope you are up and running soon .Thx for help. I'll get to discord.![]()
Just copy the SSDT to ACPI folder under OC and update the config to load the SSDT.I'm lost with the next step of this SSDT. What is the process of implementation. Maybe we can PM and you could point me in the direction if you don't mind?
<key>ACPI</key>
<dict>
<key>Add</key>
<array>
<dict>
<key>Enabled</key>
<true/>
<key>Comment</key>
<string>SSDT-EC-USBX-AMD.aml</string>
<key>Path</key>
</dict>
<dict>
<key>Enabled</key>
<true/>
<key>Comment</key>
<string>SSDT-NVME.aml</string>
<key>Path</key>
</dict>
<dict>
<key>Enabled</key>
<true/>
<key>Comment</key>
<string>SSDT-PLUG.aml</string>
<key>Path</key>
</dict>
<dict>
<key>Enabled</key>
<true/>
<key>Comment</key>
<string>SSDT-XHC.aml</string>
<key>Path</key>
</dict>
</array>
You can skip it. It is not absolutely required.
Good Luck. Let me know if Sleep Works. In my case If I don't have any USB devices connected (including keyboard, mouse) Sleep kinda works. If I try sleeping it will wake up immediately, retry makes it go to sleep. The Power is switched off. I can wake it up only by pressing the power button. Would love to hear back your experience with sleep.Ok well that SSDT did its job. Thanks for the support. Now if I could just get sleep working...
Intresting. Thanks for posting back. Would you be able to see if the behaviour changes without any USB devices? Try with BlueTooth Keyboard and mouse and see if it works any better?
