Sonoma Install complete, I need little help.
dijimet
Hello friends,
I have just succesfully installed Mac os Sonoma. But my ethernet is not working. Sonoma does not see ethernet card. My ethernet card Realtek 2.5gb
My system:
AMD 7900X3D
Gigabyte X670 AX Gaming X
AMD 6600XT
32gb ram
I used someone EFI from this forum's sccuess builds. My EFI is here.
leesurone
Hello friends,
My system:
AMD 7900X3D
AMD 6600XT
32gb ram
Are you using a Fenvi Wifi/ Bluetooth card? Looks like you have the kexts needed to run OCLP to allow a Fenvi Wireless card to work but its possible it conflicting with your build. I turned those and some other kexts off, could also be related to you Device Properties if your board isn't the same as the EFI you copied.
  • EFI-2.zip
dijimet
It did not work. Sonoma does not see my realtek 2.5gb ethernet
my bios settings:
Above Decoding : Enable
Resize Bar : Enable
