I removed the note as plugged on USB devices can cause sleep issues in any port in my experience, especially USB 2 devices. When I left the note I suspected the presence of the controller itself as a cause of issues which turned out to be false.
I don’t know why he didn’t mention the BCM94360NG. It is often recommended as a replacement that is supported by MacOS without the need for additional kexts. And since it has the same size as the AX200 you can just replace the card without any issues. It just costs a little more due to this, but paying 20 bucks more for a seamless integration is reasonable.
Hackintosh macOS BCM94360NG M.2 Wifi Karte Dual Band 1200Mbps 5Ghz Bluetooth 4,0 802,11 ac Drahtlose Adapter Als DW1560 BCM94352Z - AliExpress 7
Smarter Shopping, Better Living! Aliexpress.coma.aliexpress.com
Wait - they brought "Above 4G Decoding" back?Just finished updating to the latest BIOS 2.70. Everything is still working.
ASRock was busy and didn't only update the AGESA but also seems to have reacted to my feedback. Quite a lot of features were added or added back. Uncore can now be disabled same as Above 4G decoding. Also you can now set the frequency per CCX, allowing to apply determined by Ryzen Clock Tuner to optimize performance.
Yeah, I had a similar impression that tech people I got responses from were genuinely interested why the hell was that option so crucial to me.Yep, the also brought back the per CCX frequency option and an auto setting for uncore I requested some time ago.
The conversation I had with their tech support was more constructive and he said he'll forward my suggestion to their developers. I'm pleasantly surprised to find 2.70 with a lot more options.
