Running Mojave in Parallels, Virtualbox or Fusion. Is it possible?
vanquish
I recently had a need to run some older 32 bit apps and as I am using BigSur I can't do this. So someone suggested I use Parallels to install Mojave or High Sierra. The only problem is, they don't work.
Virtualbox won't recognise my USB. Or rather it sees that I have a USB but it won't boot from it. It also won't load any disc image of macOS. I have the same issues with Fusion.
Parallels does recognise the mac installer but when I try to run it I get an error message "Unable to load the Parallels driver".
I can run Windows 10 in Virtualbox but not any version of macOS🤔
