I'm hoping I could get some more sets of eyes on my EFI/config to see what I'm missing. I was hoping for a smooth transition over to this motherboard, but I keep getting stuck. I am getting to the bootpicker, but then when I select install MacOS, the Apple logo appears, the progress bar might fill up about a quarter of the way, and then I'll get prohibited sign with the apple support website (first pic attached). I thought that maybe I needed to try the different MMIO whitelist values, and using just the first actually got me into the MacOS recovery/installation! I was able to change language to english, format my SSD, but then after I tried to install, I got an error message that my installer was damaged. Oddly enough, I recreated my USB stick, used the same EFI, but could never get back to the installer... With my original ITX build, all I was missing was the AppleMCEReporterDisabler.kext so I'm hoping it's another small silly mistake!
Parts being used:
Parts being used:
- 7950X CPU- iGPU disabled in BIOS
- ASUS X670E ProArt Motherboard, should be following all recommended BIOS settings, i've triple checked.
- 5600XT for installation purposes- will move to 6950XT once I can get the PCIE address to spoof the device-id using gfxutil once after I install MacOS
- 64GB (32x2) Corsair Dominator Platinum
- WD Black SN850X 2TB NVME (for MacOS)
- Fenvi T919- first time going pci for wifi/bluetooth, so I probably also have not set this up as I should.
- regenerated MMIO values (though I believe they were the same as the ITX)
- Updated SBUS for my motherboard (left original SSDT-SBUS-MCHC
- Created new USB map in windows, though I've never been great at this...
- You might see I disabled some ethernet things for now, while I get things figured out
- Trying to use MacPro and the same platform info, serial, patches, etc as my original build, since CPU didn't change.
Googling around, I've seen many people in the past encounter this, but with just as many solutions haha. Hoping someone with more expertise could share any insight. Could it be GPU related? Is there a boot arg for 5600xt I'm forgetting about (I am using agdpmod=pikera)?. Is it related to USB ports? This board has more than I've ever had in my life lol! Should I create an install USB stick with a slightly earlier version of ventura or OC? Something else simple that I'm forgetting? Any help would be greatly appreciated! Hoping I can get back to troubleshooting tomorrow evening, but may even have to delay until the weekend.281:857 00:375 OCI4: Matching override 09B16B2B with 09B16B2B - success
284:434 02:576 OCSMC: SmcReadValue Key 4D535463 Size 1
284:709 00:275 OCSMC: SmcReadValue Key 4D534163 Size 2
