Problems after Opencore update
mgdesigma
r5 3600
I tryed to update opencore, but after this macos doesnt work. I tryed to do everything that i search on forum but i cant fix it
my pc:
motherboard: b450 ds3h
cpu: r5 3600
memory: 16gb(2x8gb)
gpu: sapphire nitro rx5700xt
Your config.plist contains an older set of AMD kernel patches, there are only 22 x patches in your config. This is why you couldn't install Sequoia. The patches are set to work with MaxKernel > 23.99.99, which is the designation for Sonoma.
Here is a link to the latest version of the AMD Kernel Patches, which work with Sequoia. There are 25 x patches in the latest version.
You don't need -lilubetaall boot argument with Sequoia or Sonoma.
