Problem with VirtualBox and VMware Fusion
Xsiomix
I can't understand what the problem is before this on Catalina VirtualBox worked
xock
It seem to be the problem of hardware virtualization. New versions of wmware not uses a custom kernel extension.
Xsiomix
I just can't figure out what kind of kexts I need or not, is there an instruction on how to run a virtual machine on a hackintosh with a risen? Do I need to edit confing.plis or not.
Only VBox will work due to others using the Apple Hypervisor which won't work on AMD. For VBox though there are some steps to take. Grab the latest version and run the uninstall tool that's provided.
Before rebooting run sudo csrutil clear in Terminal. Now reboot.
Now install the latest version, once installed approve the system extensions in the System Preferences -> Security & Privacy Window and reboot.
VBox should now run.
Xsiomix
I just wanted to completely switch to Mac OS, but I can't live without my favorite game, it's only on Windows, and in virtual box only 256MB
Yeah that's a limitation of the HV that VBox uses. Just use a dual boot. OC will boot Windows or macOS depending on your choice.
