Problem rog strix b550-i ethernet not working
melkus
Hi,
I am trying to install macOS Catalina using https://dortania.github.io/OpenCore-Install-Guide/
I am not able to activate my ethernet connection (to install macOS Recovery).
My kexts : AppleALC.kext, FakePCIID.kext, FakePCIID_Intel_HDMI_Audio.kext, FakePCIID_Intel_I225-V.kext, Lilu.kext, VirtualSMC.kext, WhateverGreen.kext
Hardware
Motherboard: Asus ROG STRIX B550-I
Ethernet: Intel I225-V 2.5Gbit​
Audio: Realtek ALCS1220A​
CPU: Ryzen 7 3700x
GPU: Asus Rog Strix RX 5500 XT O8G
RAM: HYPERX FURY DDR4 2666 16GB(8G×2)
Do you have any idea?
Thanks.
varunjain16
Hi,
Hardware
CPU: Ryzen 7 3700x
Thanks.
Hey would you mind sharing your EFI folder ?
I have an Asus tuf gaming b550 mobo and I am unable to get beyond 'exitbs' error.
melkus
Hi,
I found a way to make it works !
Also I am able to use iCloud, AppStore, iMessage, FaceTime,...
But the sound doesn't work properly.
The solution to enable my ethernet :
  1. Use these kexts : FakePCIID.kext, FakePCIID_Intel_I225-V.kext
  2. Update config.plist (DeviceProperties)
<key>DeviceProperties</key>
<dict>
<key>Add</key>
<dict>
<key>PciRoot(0x0)/Pci(0x1,0x2)/Pci(0x0,0x2)/Pci(0x9,0x0)/Pci(0x0,0x0)</key>
<dict>
<key>device-id</key>
<data>8hUAAA==</data>
</dict>
</dict>
<key>Delete</key>
<dict/>
</dict>
Next step : Enable wifi... if anyone can help :rolleyes: (without changing my wifi card).
Here my EFI ;)
trbsfelix
Hi,
<dict>
<key>Add</key>
<dict>
<dict>
</dict>
</dict>
<key>Delete</key>
<dict/>
</dict>
Here my EFI ;)
so for me it works (internet access, iCloud Synchronisation) but I can't download other apps nor update them.
thanks for your help
