OPENCORE OCB:Startimage Failed Aborted
Redwineiii
Hello Guys,
Like the title says, OPENCORE OCB:Startimage Failed Aborted.
I am not able to boot into the recovery to install my hackintosh.
Specs:
Processor AMD Ryzen 5 3600 6-Core Processor, 3593 MHz, 6 core('s), 12 logische processor(s)
GPU NVIDIA GeForce RTX 2070
Running right now: Windows 10
RAM: 16GB
Motherboard Gigabyte (Cant see the type of motherboard, Windows says now that i have a apple motherboard. weird...)
You are welcome.
It is only your GPU that isn't compatible. The rest of your setup will work with macOS. You just need to use a different (AMD) GPU.
You would also be advised to use a separate SSD or M.2 drive for macOS (not a Samsung M.2 drive). So you can dual boot Windows and macOS from the same system.
