No sound,no bluetooth, usb ports refuse to work even mapped
Bakugan
Ryzen 5 5500U
I have a Honor Magicbook 15 with AMD Ryzen 5 5500U, my hackintosh refuses to run sound and my usb ports are kinda lacking of power(no signal to printer or USB sticks arent working).
Please help.
Issues with your USB ports can be solved by creating a custom USBMap.kext in macOS or a UTBMap.kext in Windows. Without the correct USB port connector types being set, your system will have Sleep/Wake issues as well as non-functioning USB ports/devices.
The Audio issue will be related to the use of AppleALC.kext and the correct audio layout-id being specified in your config.plist. As we don't know which Audio Codec your system uses we can't suggest which layout-id(s) you should try.
Please help.
Can you please share your EFI folder, im in super need, Thank you in advanced.
@Bakugan you need to provide some more information about your Honor Magicbook 15 laptop before anyone can help you fix the audio and bluetooth issues.
Which Bluetooth/Wireless card is installed in the laptop - Realtek, Mediatek, Intel?
Which Audio codec is in use in the laptop - Realtek ALCxxx, or any other codec?
Does it contain a USB audio device?
Can you please share your EFI folder, I have too Honor 15 with Ryzen 5500u and I can't get to the installer.
AppleALC.kext is irrelevant on AMD based CPUs.
Please help.
For sound problems you should look into using VoodooHDA.kext. AppleALC.kext doesn't work on AMD CPUs
Don't know where you got that idea from but it is wrong.
AMD Ryzen motherboards use Realtek Audio Codecs and require AppleALC.kext for builtin audio to work.
Your old FX series didn't and relied on VoodooHDA.kext.
