My Monterey cpu crush and power-off randomly after into OS serveral mins.
Loewe_Wong
What happen to me is: when I boot into OS, everything is OK, WI-FI is OK, bluetooth is OK, mouse is OK, keyboard is OK, but after several minites(about 2-10 mins), suddenly, the screen is black, and PC is reboot out of control. THIS SITUATION happened everytime.​
My device:​
Motherboard:ASUS B550 PROART​
CPU: Ryzen 5600​
RAM: Micron 32G X 2 (XMP to 3200MT)​
NVROM: Colorful PCIE 4.0 x 4 512G & Kioxia RC20 1T PCIE 3.0 x 4​
GPU: SAPPHIRE RX 590 8G​
Bootloader: Opencore 0.9.4​
MacOs: 12.6.4​
BIOS: 4G decode & resizebar /disable​
XMP /disable​
EFI:​
See in the attach files
Here is the informaton MacOS info me :
panic(cpu 2 caller 0xffffff8012dcdd93): Kernel trap at 0xffffff801340d0ea, type 13=general protection, registers:
CR0: 0x0000000080010033, CR2: 0x00000001061fe000, CR3: 0x00000001b84d0000, CR4: 0x00000000003406e0
RAX: 0xbb019541992d4bd6, RBX: 0xffffff95a741d030, RCX: 0x0000000000000001, RDX: 0xffffffd58eedbca0
RSP: 0xffffffd58eedbcc0, RBP: 0xffffffd58eedbce0, RSI: 0xffffff95a741d030, RDI: 0xffffff95a741d030
R8: 0x0000000000000000, R9: 0x0000000000000000, R10: 0xffffff80df963768, R11: 0xffffffa0d788c680
R12: 0xffffff9a723f1230, R13: 0x00000000e00002f0, R14: 0xffffff9a723f1230, R15: 0xffffff9a72afdfc0
RFL: 0x0000000000010286, RIP: 0xffffff801340d0ea, CS: 0x0000000000000008, SS: 0x0000000000000010
Fault CR2: 0x00000001061fe000, Error code: 0x0000000000000000, Fault CPU: 0x2, PL: 0, VF: 0
Panicked task 0xffffff8c0f83e9c0: 14 threads: pid 142: WindowServer
Backtrace (CPU 2), panicked thread: 0xffffff87452c8540, Frame : Return Address
0xffffff8012b0d170 : 0xffffff8012c7befd mach_kernel : _handle_debugger_trap + 0x41d
0xffffff8012b0d1c0 : 0xffffff8012dde636 mach_kernel : _kdp_i386_trap + 0x116
0xffffff8012b0d200 : 0xffffff8012dcd9a3 mach_kernel : _kernel_trap + 0x4d3
0xffffff8012b0d250 : 0xffffff8012c1ba70 mach_kernel : _return_from_trap + 0xe0
0xffffff8012b0d270 : 0xffffff8012c7c2cd mach_kernel : _DebuggerTrapWithState + 0xad
0xffffff8012b0d390 : 0xffffff8012c7ba86 mach_kernel : _panic_trap_to_debugger + 0x2b6
0xffffff8012b0d3f0 : 0xffffff8013514aa3 mach_kernel : _panic + 0x84
0xffffff8012b0d4e0 : 0xffffff8012dcdd93 mach_kernel : _sync_iss_to_iks + 0x2c3
0xffffff8012b0d660 : 0xffffff8012dcda76 mach_kernel : _kernel_trap + 0x5a6
0xffffff8012b0d6b0 : 0xffffff8012c1ba70 mach_kernel : _return_from_trap + 0xe0
0xffffff8012b0d6d0 : 0xffffff801340d0ea mach_kernel : __ZN18IORegistryIterator17getNextObjectFlatEv + 0xfa
0xffffffd58eedbce0 : 0xffffff801340d14c mach_kernel : __ZN18IORegistryIterator22getNextObjectRecursiveEv + 0x1c
0xffffffd58eedbd10 : 0xffffff8013480f77 mach_kernel : _is_io_registry_entry_get_property_bin_buf + 0x287
0xffffffd58eedbd80 : 0xffffff8012d86897 mach_kernel : _iokit_server_routine + 0x74f7
0xffffffd58eedbdd0 : 0xffffff8012c56a2b mach_kernel : _ipc_kmsg_send + 0x46b
0xffffffd58eedbe60 : 0xffffff8012c6d339 mach_kernel : _mach_msg_overwrite_trap + 0x2c9
0xffffffd58eedbef0 : 0xffffff8012db060a mach_kernel : _mach_call_munger64 + 0x1ea
0xffffffd58eedbfa0 : 0xffffff8012c1c256 mach_kernel : _hndl_mach_scall64 + 0x16
Process name corresponding to current thread (0xffffff87452c8540): WindowServer
Boot args: -v debug=0x100 keepsyms=1 alcid=3 chunklist-security-epoch=0 -chunklist-no-rev2-dev chunklist-security-epoch=0 -chunklist-no-rev2-dev
Mac OS version:
21G646
Kernel version:
Darwin Kernel Version 21.6.0: Mon Apr 24 21:10:53 PDT 2023; root:xnu-8020.240.18.701.5~1/RELEASE_X86_64
Kernel UUID: B91C3306-5CF4-3F44-A94E-F4F006FE99E2
KernelCache slide: 0x0000000012a00000
KernelCache base: 0xffffff8012c00000
Kernel slide: 0x0000000012a10000
Kernel text base: 0xffffff8012c10000
__HIB text base: 0xffffff8012b00000
System model name: MacPro7,1 (Mac-27AD2F918AE68F61)
System shutdown begun: NO
Panic diags file available: NO (0xe00002bc)
Hibernation exit count: 0
System uptime in nanoseconds: 493092072881
Last Sleep: absolute base_tsc base_nano
Uptime : 0x00000072ce93f01f
Sleep : 0x0000000000000000 0x0000000000000000 0x0000000000000000
Wake : 0x0000000000000000 0x0000002bd15fdedd 0x0000000000000000
Compressor Info: 0% of compressed pages limit (OK) and 0% of segments limit (OK) with 0 swapfiles and OK swap space
Zone info:
Zone map: 0xffffff80d7953000 - 0xffffffa0d7953000
. PGZ : 0xffffff80d7953000 - 0xffffff80df954000
. VM : 0xffffff80df954000 - 0xffffff85ab2ed000
. RO : 0xffffff85ab2ed000 - 0xffffff8744620000
. GEN0 : 0xffffff8744620000 - 0xffffff8c0ffb9000
. GEN1 : 0xffffff8c0ffb9000 - 0xffffff90db952000
. GEN2 : 0xffffff90db952000 - 0xffffff95a72eb000
. GEN3 : 0xffffff95a72eb000 - 0xffffff9a72c85000
. DATA : 0xffffff9a72c85000 - 0xffffffa0d7953000
Metadata: 0xffffff805f441000 - 0xffffff807f441000
Bitmaps : 0xffffff807f441000 - 0xffffff8097441000
THX SO MUCH to debug my problem, I appreciate it VERY MUCH(●'◡'●)!
Loewe_Wong
There is another info MacOS providing :
panic(cpu 2 caller 0xffffff8011fcdd93): Kernel trap at 0xffffff80152021e2, type 14=page fault, registers:
CR0: 0x0000000080010033, CR2: 0xffffff8c61e40032, CR3: 0x0000000e8a650000, CR4: 0x00000000003406e0
RAX: 0xffffff8c61e40030, RBX: 0xffffff8b91db6aa0, RCX: 0x000000001a00a1ff, RDX: 0xffffffeac8d23218
RSP: 0xffffffeac8d231d0, RBP: 0xffffffeac8d23200, RSI: 0x000000001a00a1ff, RDI: 0xffffff8b91db6aa0
R8: 0xffffffeac8d23310, R9: 0xffffffeac8d230d4, R10: 0x000000000002251b, R11: 0x000000000000000e
R12: 0x00000000340143ff, R13: 0x0000000000000000, R14: 0xffffffeac8d23230, R15: 0xffffffeac8d23218
RFL: 0x0000000000010246, RIP: 0xffffff80152021e2, CS: 0x0000000000000008, SS: 0x0000000000000010
Fault CR2: 0xffffff8c61e40032, Error code: 0x0000000000000000, Fault CPU: 0x2, PL: 0, VF: 1
Panicked task 0xffffff95308796d0: 8 threads: pid 574: mediaanalysisd
Backtrace (CPU 2), panicked thread: 0xffffff8b903b8aa0, Frame : Return Address
0xffffffeac8d22b80 : 0xffffff8011e7befd mach_kernel : _handle_debugger_trap + 0x41d
0xffffffeac8d22bd0 : 0xffffff8011fde636 mach_kernel : _kdp_i386_trap + 0x116
0xffffffeac8d22c10 : 0xffffff8011fcd9a3 mach_kernel : _kernel_trap + 0x4d3
0xffffffeac8d22c60 : 0xffffff8011e1ba70 mach_kernel : _return_from_trap + 0xe0
0xffffffeac8d22c80 : 0xffffff8011e7c2cd mach_kernel : _DebuggerTrapWithState + 0xad
0xffffffeac8d22da0 : 0xffffff8011e7ba86 mach_kernel : _panic_trap_to_debugger + 0x2b6
0xffffffeac8d22e00 : 0xffffff8012714aa3 mach_kernel : _panic + 0x84
0xffffffeac8d22ef0 : 0xffffff8011fcdd93 mach_kernel : _sync_iss_to_iks + 0x2c3
0xffffffeac8d23070 : 0xffffff8011fcda76 mach_kernel : _kernel_trap + 0x5a6
0xffffffeac8d230c0 : 0xffffff8011e1ba70 mach_kernel : _return_from_trap + 0xe0
0xffffffeac8d230e0 : 0xffffff80152021e2 com.apple.filesystems.apfs : _btree_node_key_ptr + 0x44
0xffffffeac8d23200 : 0xffffff8015203d88 com.apple.filesystems.apfs : _bt_search_node_insert + 0x92
0xffffffeac8d23270 : 0xffffff801520c99c com.apple.filesystems.apfs : __bt_lookup_variant + 0x442
0xffffffeac8d23390 : 0xffffff801520cf90 com.apple.filesystems.apfs : _bt_iterator_init_with_hint + 0xfd
0xffffffeac8d23400 : 0xffffff80151c51ac com.apple.filesystems.apfs : _iterate_jobjs_with_hint_and_snap + 0x1e4
0xffffffeac8d234e0 : 0xffffff801516ab01 com.apple.filesystems.apfs : _apfs_vnop_readdir + 0x554
0xffffffeac8d23d10 : 0xffffff801213e436 mach_kernel : _vnode_readdir64 + 0x3b6
0xffffffeac8d23dd0 : 0xffffff801213e927 mach_kernel : _getdirentries + 0x497
0xffffffeac8d23ef0 : 0xffffff801213eb7a mach_kernel : _getdirentries64 + 0x6a
0xffffffeac8d23f40 : 0xffffff8012586bdb mach_kernel : _unix_syscall64 + 0x1fb
0xffffffeac8d23fa0 : 0xffffff8011e1c236 mach_kernel : _hndl_unix_scall64 + 0x16
com.apple.filesystems.apfs(1934.141.2)[78E6D3DF-9A4D-3F46-B298-3C52A83F9108]@0xffffff801510c000->0xffffff801528afff
dependency: com.apple.driver.AppleEFINVRAM(2.1)[5D7C7E5D-CA94-360D-9A05-384B539B1A7A]@0xffffff80133b2000->0xffffff80133bbfff
dependency: com.apple.driver.AppleEffaceableStorage(1.0)[B97B3370-F304-3E32-8356-E2CB9B0255A7]@0xffffff80133c8000->0xffffff80133cdfff
dependency: com.apple.iokit.CoreAnalyticsFamily(1)[3542B048-616C-33A7-A22B-532EDFC1A466]@0xffffff80138d4000->0xffffff80138dbfff
dependency: com.apple.iokit.IOStorageFamily(2.1)[EDB37126-8C1E-3BF1-B95A-07D7074F3AC6]@0xffffff8014b7c000->0xffffff8014b92fff
dependency: com.apple.kec.corecrypto(12.0)[08AB2CDD-6687-35EA-BA0B-2974BDB2FB9C]@0xffffff80152c4000->0xffffff8015344fff
dependency: com.apple.security.AppleImage4(4.2.0)[5DA3A952-D34E-3D9D-8C91-FD475E1DF6F0]@0xffffff801344f000->0xffffff8013467fff
Process name corresponding to current thread (0xffffff8b903b8aa0): mediaanalysisd
Mac OS version:
21G646
Kernel version:
KernelCache slide: 0x0000000011c00000
KernelCache base: 0xffffff8011e00000
Kernel slide: 0x0000000011c10000
Kernel text base: 0xffffff8011e10000
__HIB text base: 0xffffff8011d00000
System uptime in nanoseconds: 76064316519
Uptime : 0x00000011b5c95f06
Wake : 0x0000000000000000 0x0000002cf3ada45b 0x0000000000000000
Zone info:
Zone map: 0xffffff805e5f9000 - 0xffffffa05e5f9000
. PGZ : 0xffffff805e5f9000 - 0xffffff80665fa000
. VM : 0xffffff80665fa000 - 0xffffff8531f93000
. RO : 0xffffff8531f93000 - 0xffffff86cb2c6000
. GEN0 : 0xffffff86cb2c6000 - 0xffffff8b96c5f000
. GEN1 : 0xffffff8b96c5f000 - 0xffffff90625f8000
. GEN2 : 0xffffff90625f8000 - 0xffffff952df91000
. GEN3 : 0xffffff952df91000 - 0xffffff99f992b000
. DATA : 0xffffff99f992b000 - 0xffffffa05e5f9000
Metadata: 0xfffffff55750a000 - 0xfffffff57750a000
Bitmaps : 0xfffffff57750a000 - 0xfffffff58f50a000
There is nothing in your OC EFI that shouts out as an obvious cause for this issue. It is similar enough to my two B550 setups to not raise any major flags. So I would look at a possible hardware issue. With your NVMe or USB devices being the most likely suspects.
Does this Kernel Panic and system reboot happen after or as you access a specific NVME drive or USB device?
