Monterey (12) - OCB: LoadImage Failed Unsupported
HHal3nzy
Hello,
after booting from the USB I receive the following error
OCB: LoadImage Failed - Unsupported
CPU : AMD Ryzen 5 3600
GPU : AMD Radeon RX 460
Motherboaed : asrock b450m-hdv r4.0
Here is my EFI Folder
Any help is greatly appreciated.
Thank you
  • EFI.7z
Try this revised EFI.
I used the same PlatformInfo SMBIOS data as was in your original EFI. So which version of macOS are you installing?
The MacPro7,1 SMBIOS is supported when running or installing Big Sur and Monterey.
Try this revised EFI, which has SMBIOS data for a MacPro6,1, which has been checked against Apple Support page, it is not being used by a real Mac. Nothing else has been changed.
HHal3nzy
Thank you I forgot to thank you
RyzeCooker
I have to ask, what is up with that profile pic?
