- Joined
- Jun 2, 2020
- Messages
- 105
Hi to all.
Just wanted to share my experience as it may help others with similar GPU.
I was always getting a black screen after the 1st Apple Boot Logo with the 6600xt even if I had added in the boot args the "agdpmod=pikera".
I don't know if this has been mentioned but the way I made it work in 12.4 was also to add the "-lilubetaall" argument. This is the only way it don't get a black screen and everything is working perfectly.
(You can also add the unfairgva=1 boot argument so as to have a working appleTV and Netflix in Safari.)
On another note, my Asrock mobo uses the i211 ethernet and this works great with AppleIGB kext and the e1000=1 boot argument.
Bluetooth also works great with bluetoolfixup kext and removal of intelbluetoothinjector kext.
I attach some pics and my boot arguments. Many thanks to all the community.
EFI: https://drive.google.com/file/d/1m-pfEMnnyIXpY090KbkLDDdqJVgYt7Z4/view?usp=sharing.
I have deleted in config plist/Platform info the information about Serial number, UUID, MLB and ROM, so you need to insert yours.
I think it works great with this mobo, a 6core Ryzen CPU and this GPU.
