- Joined
- Jul 5, 2022
- Messages
- 2
Hello everyone!
I managed to crate the USB and install Monterey macOS on my SSD with these specs:
CPU: AMD Ryzen 7 5700G with Radeon Graphics (disabled the graphics)
GPU: Radeon RX 580 Series
RAM: 32GB
Motherboard: Asus ROG STRIX B550-E GAMING (AM4)
Audio Codec: Realtek High Definition Audio
Ethernet Card: Intel(R) Ethernet I225-V
Wifi/BT Card: Intel(R) Wi-Fi 6 AX200 160MHz and Bluetooth
After install, the macOS welcome setup appeared , i chose the Region, it suddenly refreshed, apple logo appeared again , it loaded and after a few seconds the welcome setup appeared again, and it did this non-stop. I decided to force restart the pc. The welcome screen appeared once again, this time i selected the region , but after i press not now at accesibility setup it just instantly restarts. I keeped trying and trying and trying restart after restart i managed to get into macOS. It was still restarting after a few seconds or a few minutes after getting into macOS, usually seconds.
VIDEO : LINK
I decided to reinstall the macOS and tought this will fix but no, after reinstall the refresh loop at region happened again, force restart and now i cant get past accesibility setup because the pc restarts very fast after it boots up. Im aware this may be a hardware problem , i have another SSD wich is with windows , it works well no problem at all. Anyone got any ideea how can i fix this? Thank you!
Speccy info :
Summary
CPU
My EFI :
EFI
Update 1 : Installed the AMD CPU power management kexts and sadly didn’t fix it. Sometimes after the random restarts the pc doesn’t detect my usb anymore , I have to remove it and put it back again.
RAM: 32GB
VIDEO : LINK
Speccy info :
Summary
CPU
My EFI :
EFI
