LoadImage Failed - Unsupported
kvmrnn
Hello everyone, there was such a problem. macOS Big Sur I want to upgrade to Monterey, but I get an error LoadImage Failed - Unsupported
CPU: Ryzen 5 2400GE
GPU: Nvidia GTX 1060 6 gb
Motherboard: Asus pro B450M k-ii
I will be glad if you help me, here is mine EFI
Your NVIDIA GPU is not supported in any version of macOS newer than High Sierra. Even with High Sierra it is not natively supported, it requires the Nvidia Web Drivers to be installed for it to work in macOS.
Either install High Sierra or change your NVIDIA GPU for a macOS compatible GPU.
A compatible GPU would be one of those listed in the Dortania GPU Buyers Guide linked below.
Look at the 'Modern GPU's' AMD and Nvidia links in the left hand column. Not the Legacy links..
