issue disabling Nvidia GPU
tristan
hi, I have a issue when I disable Nvidia GPU on ventura... Now I have a dual boot (windows and hackingosh Ventura 13.4) and two gpu: GTX 1070Ti 8GB for windows and Sapphire AMD Rx570 8GB for Ventura.
I try to disable via config.plist ( pci gpu-disabled ) and via SSDT (like opencore manual), but don´t work. The fist time works fine, but the second reboot not, and loop restart all the time.
Only works again if I reset de nvram, but only one time until reboot.
thanks for your help!
Lorys89
Post the efi And tell me what os you try
tristan
Thank you very much for the help!
Because I am newbie in Hackintosh and I want to learn... I am going to start again, reset bios and buildt a new EFI folder with the last versions of opencore and kexts, map of usb´s, modify DSDT´s (thanks to Edhawk... cause I don´t know this and never seen before), and try to disable Nvidia GPU in MacOs ( my headache )....
I'm sure when finish, I'll back and ask more questions... :)
tristan
IT WORKS !!!!
I had a mistake in boot args. I set "4G Decoding" to enable on Bios, and write in boot-args : "ncpi=0x3000". This is the reason that stucks on pci boot section when nvidia GPU was plugin.
Thanks again, specially @Edhawk for your time and help.
Glad To hear it works.
tristan
Is there anyway to stop the disabled nvidia gpu fans? or shouldn´t stop then...
I attach this files if help them... (actual EFI folder, pci devices from hackingtool, and ioreg file)
  • pci devices.zip
  • tristan1412’s Mac Pro.zip
  • EFI tristan.zip
