Instalação do sistema
Julio Cesar
Como instalar o sistema nas seguintes configurações:
Placa Mae: Tufgaming x570
Processador: AMD Ryzen 5 3600x
Placa de video: GTX 1070
Follow the Dortania Ryzen guide to install macOS High Sierra.
Sigue la guía de Dortania Ryzen para instalar macOS High Sierra.
Use the specific boot argument required for using the Nvidia Web Drivers, as your GTX 1070 is not supported natively and requires the Nvidia drivers.
Utilice el argumento de arranque específico necesario para usar los controladores web de Nvidia, ya que su GTX 1070 no es compatible de forma nativa y requiere los controladores Nvidia.
The GPU is not supported in any newer version of macOS.
La GPU no es compatible con ninguna versión más reciente de macOS.
clover84
<offtopic> it was Portuguese :) </offtopic>
Hey @Edhawk, what would you say about the OCAuxiliaryTools? In general it looks like just about anybody can build a basic EFI with this tool (with presets) and then fine-tune as needed. I've been using it for about a year now, with just a few minor issues. A good starting point for those who are lazy or can't read the Dortania guide.
Apple translate said it was translating from Spanish!
Yeah I suppose it would be easier for a noob using that app.
