Techpro
my rig doesn't even start putting text in the screen after selecting my macos installer then reboots
Thanks
  • EFI.7z
Techpro
someone help pls it reboots at preboot
Techpro
sorry it just shutsdown, (edited and in the opencore log get this 00:013 00:013 OC: External interface failure, fallback to builtin - Unsupported)
Techpro
then blank
dmls
I don't understand what you're talking about. You can type your source language
Try booting with the revised EFI below.
  1. I have added two kexts to the /EFI/OC/Kexts folder - AppleMCEReporterDisabler.kext and RestrictEvents.kext, with config.plist entries to enable these two kexts.
  2. I have changed SecureBootModel from - Default to Disabled, as you require the Nvidia Web Drivers.
  3. I have removed the obsolete Intel Kernel Patches and placed the AMD patches in the correct location within the config.plist.
  4. I have cleaned up the config.plist by removing some unnecessary place holder entries.
See if this boots your system.
