Help to correct errors that will occur when installing mac os ventura
SpringCat
16
AMD Ryzen 5 5600X
several errors occurred
1. USDBToolsBox XHC1: waitForMatchingService failed or tome out
2. gets stuck on this message: the regents of the university of california
I don't know what to do anymore and I reset it Nvram. after that it throws the first error.
my laptop Honor magicbook 15 amd ryzen 5 5500u 8gb/512gb (BMH-WDX9)
opencore 0.9.7
thanks in advance for your answers and help !
Sorry for my English, I'm still learning it and I write with mistakes! I hope it's clear
    EFI.zip
Cleaned up your EFI and updated it. I'm assuming you've made the USB map kexts on Windows so I've left those in place. Your setup for the PS2 kexts may need some tweaking but try it as is. Unsure what LAN NIC is on that laptop so I've left RTL8111 there.
You had device properties full of every device and Whatevergreen installed. Both of these are removed as both conflict with NootedRed.
I use an adapter from Qualcomm and I can't find what version
I have a problem like this, how can I solve it? Can you help me?
Qualcom WiFi? That won't work in macOS. You'd either need to use LAN or swap it to a supported WiFi chip.
As for where it's stuck. Can you provide a full picture of whats on the screen.
Unfortunately, I have WiFi from Qualcomm, but is it really impossible to bypass all this somehow? Or will Mac OS not fit on this laptop at all?!
Try adding AMFIPass.kext to your /EFI/OC/Kexts folder with a corresponding entry in your config.plist.
See if adding this kext gets you past this point in the boot process.
Thanks for your help, I tried it but the error didn't go away!
