hello everyone o/
been hackintoshing for a few days, its been fun and i got a working sonoma install
unfortunately i have a big problem which makes the system really annoying to use - my mouse moves perfectly fine, but sometimes it'll drop inputs when i want to release it
doesnt matter if im dragging a window or selecting something on the desktop, it won't release. same thing with the dock - sometimes clicking on an app drags it. my only solution to this has been to click a few times to make the dragging stop (linked video demonstrates this)
im using the latest version of sonoma, opencore release (not debug) 1.0.8, my smbios is the iMacPro1,1 & my specs can be seen in my signature
i've tried lots of stuff, but nothing here works:
(P.S. my mouse isn't broken, it works perfectly fine in windows)
- changing the polling rate in windows - does nothing in macos, it defaults back to 1000hz. as far as im aware, there's no way for me to change the polling rate of my mouse in macos
- using different ports on the back of my motherboard (plugging the mouse either into a usb 2.0 port or into a usb 3.2 gen 1 port doesn't change anything)
- using xhciportlimit without usbmap.kext and vice versa
- disabling global c-states & enabling xhci hand-off in bios
- talking to ai - always gets to "try an office mouse or get a dedicated gpu"
- safe boot doesn't work since i dont have a dedicated gpu, only my igpu
- checked the macos console app while doing the dragging test on the terminal - keeps spamming with "-[TUINSCursorUIController scheduleUpdateCursorPosition]"
