[Help] Freezing on the MacOS install screen
bthomp2000
NOTE: Moving from Big Sur thread to here as I am installing Monterey
Hardware:
  • CPU: Ryzen 5 1600
  • GPU: Radeon RX 6600 XT
  • RAM: 16GB DDR4 1200MHz
  • Motherboard: MSI B450 Tomahawk Max II
  • Ethernet: Realtek PCIe GbE Family Controller
  • Storage: Western Digital WDS500G2B0A 500GB SATA, 2.5"
EFI zip directory attached
Other info:
Dortania: https://dortania.github.io/OpenCore-Install-Guide/AMD/zen.html
Using OpenCorePkg 0.7.6
Installing MacOS Monterey (12.1)
Problem:
I am able to create the flashdrive and get to the installer page. After about 4-8 minutes into the installation, it freezes (no keyboard or mouse inputs working, gets stuck on current screen). I have left it over night and still frozen on the same screen. This happens even without entering the installation. If I just stay on the initial screen, it will still freeze after some time.
Things I've tried:
SMBIOS: MacPro7,1 and iMacPro1,1
Big Sur, Monterey
Different flash drive / ports on my PC
Creating flash drive on Mac and Windows
Release / Debug versions of OC
I have also attached an image of the installer log as it freezes:
RyzeCooker
MSI boards are notoriously incompatible with Monterey. There are number of threads on it. Sometimes regressing the BIOS will find one that works but that's trial and error. Afraid you need to stick with Big Sur.
bthomp2000
Thanks for the reply! I'm fine with Big Sur but I've read elsewhere that the Radeon RX 6600 XT is only compatible with Monterey 12.1, do you know if this is true?
Specifically referring to this post: Beta 12.1 Out! (AMD 6600XT support added) : hackintosh (reddit.com)
Yes it is true. You need to be running Monterey 12.1 for the RX6600 dGPU to w in macOS.
