Convert my Monterey EFI to work with Ventura
joostiphone
47
35
18
github.com
i7-9700k
Hi, my current EFI which works perfectly with MacOS Monterey doesn't seem to work with MacOS Ventura. I've spent several days to get it to work, without success.
Can someone upgrade my EFI to OpenCore 0.8.2 including the required changes for Ventura?
My hardware:
  • PC Case: Fractal Design Define R6 USB-C TG
  • Processor: Intel Core i7 9700K, 9th Gen (Code name: Coffee Lake)
  • Motherboard: Gigabyte Z390 Designare
  • Sound card (onboard): ALC 1220-VB audio controller
  • SSD storage: Crucial Crucial MX500, 1TB
  • Graphic card: AMD RX 6800 XT 16GB
  • Fenvi T919 for WiFi/Bluetooth, AirDrop, Apple Watch Unlock, etc.
  • Power Supply: Be quiet! Dark Power 12 1000W
  • Memory (RAM): Corsair Vengeance LPX (2x 16GB, total 32GB)
  • Display: iiyama G-Master GB3466WQSU-B1 UltraWideScreen, 34 inch.
Many thanks.
Joost
Hi everyone…
Looking to see if anyone can help me update my efi to the latest open core. Would like to test out Ventura on a separate drive. My specs are:
Motherboard: MSI x570 Godlike​
CPU: Ryzen™ 9 5950X
Video Card: SAPPHIRE AMD Radeon RX 6800 XT 16GB GDDR6
Memory: G.SKILL TridentZ 3200 128GB ram
Power: CORSAIR HXi Series HX850i 850W power supply
SSD: Team Group MP33 PRO M.2 2280 1TB ssd X3
Monitors: LG 27UL850-W 27" Ultra HD 3840 x 2160 4K monitor x2
Big Sur 11.6.4 OC 0.78
Not sure if Ventura has the same issues with MSI MB as Monterey. Currently running Big Sur with no problems.
Thanks for your help
Great @CaseySJ
I will try it and I will come with an feedback. Thank you very much!!!
Also, can you post the steps how to upgrade it? I really like to know... if is possible of course.
LE: @CaseySJ unfortunetly it isn't working...
Hello everyone, I wonder if you can make the EFI folder working in Monterrey compatible with Ventura 13.0 (22A5311f) version.
@CaseySJ
