Clover Experimental Patches for 10.13.x, 10.14.x and 10.15.x
Now working the clock. But now no sound i tried VoodooHDA and AppleALC but not at the same time. With applealc tried the alcid layout codecs, no sound.
I tried the DSDT patches AZAL to HDEF and HDAS to HDEF and tried without this patches.
Thanks for your prompt reply.
I still got KP with Shaneee's patches. Can you share your Clover's config.plist without SN for me ? I hope I can compare it with mine to fix this.
I have attached my clover plist file that works perfect and OC plist file that also works great except reboot won't work. For clover I used nullcpupowermanagement kext instead of nullethernet kext in OC
I used the patch plist file you posted but couldn't boot.
Thanks for your prompt reply and help.
Modified my config.plist based upon the difference of ACPI between mine and yours I can boot from 10.15.1 to 10.15.6 beta2 without KP now.
Hello jsl2020, I tried your config.plist and I could boot into my 10.15.3, but without Sound. With the patch.plist from Shaneee I had a KernelPanic. Grettings Maclinux1960
Helllo svk77,
can you share your config.plist for Clover r5119? I used the config.plist from jsl2020, but Sound does not work.
Greetings Maclinux1960
my config.plist is almost the same as in this post
sound works - built-in codec, and usb "sound card for $1 from aliexpress"
hdmi did not check checked, works.
voodoohda
hdmi did not check.
voodoohda
Hello svk77,
I found a Solution for the VoodooHDA.kext Problem, what is taken me 6 Weeks after searching Google und posting in other Forums.
It is the FSB Frequency what must be correct setting in OpenCore config.plist
I give you an Example for me AMD FX 6300 with 3,5 Ghz and the FSB with 200 Mhz.
I used CPU-Z in Windows the get correct FSB
The correct is exactly 200.38 Mhz, but make 200 Mhz for better calculating.
So now you have everthing you need to know.
Step 1 - Open your config.plist.
Step 2 - Go to PlatformInfo - Automatic, in the Sample the Automatic is setup to Yes. Set it to "no".
(Otherwise the Information from "PlatformInfo -DataHub" will have no Effect!!!!)
Step 3 - Set "ARTFrequency" to your CPU Frequency, in my Case 3500000000 hz = 3,5 Ghz.
(The Entries abut FSB and so on are "Hz")
Step 4 - Set "InitialTSC" also to your Frequency, in my Case 3500000000 hz = 3,5 Ghz.
Step 5 - Set "FSBFrequency" to your Bus Speed shown in CPU-Z or an other Tool of your Choice, in
my Case 20000000 hz = 200 Mhz.
Step 6 - Start with your USB Stick and check if your Sound works correct. If your Sound is to slow
and is "chopped - German - abgehackt", then set go the half of your FSB down, lets say to
10000000 hz = 100 Mhz. That is the Way I made it. Finally went down to "60000000 hz" and
the Sound is good. Off Course you can go on and make it more perfect with more small Steps
by setting down the FSB Value.
When are finish, your Entries look like this (only for the AMD FX 6300):
I hope I could help, I never forget who helped me.
Greeting from Germany, maclinux1960
Reactions: Hecatomb
I have successfully installed Mojave 10.14.6 Vanilla kernel with CLOVER and old patches (posted on some site by Shaneee or someone from those guys some months ago) and my Hackintosh works (almost, no Shutdown and FaceTime), but when I try a config.plist with these new patches I cannot even reach the CLOVER menu. Anybody knows why?
mobo: GA-990XA-UD3
cpu: FX-6300
Below are the 2 different CLOVER config.plist files
For those 15h_16h AMD CPU users may test my modified clover-config.plist which worked at 10.15.1 to 10.15.6 beta2 except 10.15.4.
mono: GA-990XA-UD3
cpu: FX-6300
I created a Catalina 10.15.6 Vanilla installer and CLOVER r5121 boot loader and used your proposed config.plist, so here is what I get when I try to boot the installer (This version of Mac OS X is not supported by this platform. Reason Mac-F42... etc). Got any idea what is going on?
Update 1
My bad. I misspelled config.plist! I corrected it and then I got stack with a kernel panic during installer boot. I have posted a picture on another comment.
I used your Clover config.plist file and I get a kernel panic at this point (see picture).
Me too! KP with Shaneee's patches.
