Can't Stop popping and crackling via USB Audio Interface
Shane Jacob
5
Hey I just recently installed AMDHSv5 on my computer.... Everything works perfectly fine except for the audio. The problem is that my on-board Realtek sound card does not work so I use Behringer UCM-22 for audio via USB. But the audio just wouldn't stop crackling and stopping.
Things I've tried-
Setting busratio and Bus speed and frequency in Clover
Removing GenericUSBXHCI kext
Installed voodooHDA but in the settings my USB audio doesn't show
Changed sample rates in MIDI Setup
Please if anyone has been able to solve this issue help me.... If my audio works then I have a perfect working High Sierra
Specs -
MB - GA-AB350-Gaming 3
CPU - Ryzen 5 1400
Graphics - GTX 1050Ti
RAM - 16 GB DDR4
Does your bios have an option to set it to use Gen 3 pcie only? You board doesn't have 4, but I had to set mine to three (from 4/Auto) to get audio weirdness to go away.
Hey thanks for the reply.. I'll give it a try and look in my BIOS and update
Hey I didn't have Gen 4 but I had Gen 3 so I switched to that... Still nothing...
Damn. It was worth a shot though. I also run audio externally (Focusrite Scarlett Solo) but I don't use VoodooHDA, never had to. Have you tried different usb ports?
I think all my ports are USB 3.0 or 3.1. When I restart the computer, It works fine for about half a minute then starts crackling. And If I unplug and plug back the USB audio interface it becomes fine for another half a minute but again goes back to crackling. Also tried USB DAC audio port
Okay I have an Update - I tried in all the ports one by one, worked in one of them. No stutters now. Will test out more with Logic Pro and other softwares and update soon... Able to access good audio now.
That's good to hear! You may want to try and map your usb ports if you haven't already. It's a one time Hassle (with a capital H) but could then rule out some kind of misinterpretation by macOS of the ports your motherboard has. Technolli has a guide for Intel Hackintoshes, you can skip the injectallusb step since that won't work on Ryzen boards.
Things I've tried-
Specs -
CPU - Ryzen 5 1400
RAM - 16 GB DDR4
bro where did you get the AMDHSv5?
