Basically the title. A couple of days ago I tried to use the EFI shared by @Middleman, but in the end I decided to do the whole process on my own once again using some kexts from the EFI he shared because I didn't know how to configure them in a way that my Motherboard's native WIFI card would work.
After trying to do everything with a lot of patience and care, at the moment of trying to install the OS, I could see the option to select my USB, after that it started the process, but everything said "Failed" once it finished, the computer shut down completely and I'm lost not knowing what I did wrong. Maybe I misunderstood something as English is my second language and I wanted to ask for your help with this. Thank you very much in advance.
My specs are:
CPU: AMD Ryzen 5 5600X @ 3.7GHz.
Motherboard: ASUS Rog Strix B550-i Gaming.
RAM: 16GB 1x16GB - (I'm waiting for an RMA from the other stick, it should be 32GB in total).
Audio Chipset: SupremeFX7.1 Audio CODEC S1220A
GPU: XFX Speedster SWFT 210 AMD Radeon™ RX 6600 XT.
WiFi & Bluetooth: Intel® Wi-Fi 6 AX200.
Lan: Intel® I225-V 2.5Gb Ethernet.
Disk: WD_Black 500GB SN750 SE NVMe.
I used OpenCore 0.8.3 to try to install macOS Monterey.
Once again, thanks in advance for the help. I hope you all have an amazing day!
My specs are:
