7800x3d and 5700 stuck on "AMDCPUSupport::start trying to init pci service..."
alexye2625
21
7800x3d
PC SPECS:
ASUS ROG STRIX B650E-F GAMING WIFI
AMD Ryzen 7 7800X3D
AMD Radeon RX 5700
Corsair Vengeance 32gb 6000mt
CT1000P510SSD8
The old text got too long, I made some changes and got some good decent progress!
It would be great for any answers or fixes because this is my 5th day working on hackintosh.
    EFI.zip
I checked my USB drive and there indeed was nothing on there except an efi, com.apple.recovery and some logs and Rufus icons for my usb
Ok, it is surprising how many people have a second EFI folder present that causes this macOS incompatibility issue.
Check that you aren’t using a specific system ID in the SecureBootModel entry in your config.plist, this needs to be set as ‘Disabled’ for an AMD hack.
The errors show in the verbose text above relate to ACPI Patches that are incorrect but present in your config.plist, or missing entirely from your config. I am not at my desk so can’t open your EFI or more importantly the config.plist to check which it is.
Well that isn't the EFI folder that I provided, or even a close family member!
It contains a lot of unnecessary kexts, a couple of useless SSDT's and is missing the ACPI Patches that would fix those ACPI errors in the verbose text you added to post #23.
Try this EFI-v2 see if you can boot in to macOS with this setup.
This EFI is based on my Working B650E-F Gaming system that runs Sequoia 15.7.4 without issue.
I am still having issues getting Tahoe to install and run smoothly on this B650E-F Gaming system. So I would suggest you install Sequoia first and then see about getting Tahoe installed later.
