32bit on High Sierra Ryzentosh
Deleted member 862
Hi, I'm new to this forum
I wanted to ask if there is any possible way to enable 32 apps on High Sierra or Mojave
They always crash when I try to open them, I found shanee Opemu and tried to replace the Kernel with the one he provided, put the code after and then reboot but they are still crashing, I'm desperate
Not to necro an old thread but since there isn't an answer, I'll give it a shot.
My solution was to stop with HSierraAMD 10.13.2 which is the final version before you start getting the "You're running applications that will soon no longer be supported". To avoid that (introduced in 10.13.3) and the 32-bit "bug", I just stayed at 10.13.2 and never have a problem with 32-bit applications, which I still use daily.
Of course, your mileage may vary.
