So i'm kstuck.. maybe it's something dumb on my part, but i'm also new to this. I followed the opencore guide, looked at some efi examples. So far i get to the install macos boot menu, it starts scrolling down and than the monitor just turns off and nothing... the EFI sanity check site say my config.plist is "ok" maybe i'm missing something.. i thought i put everything i needed in there, any help would be greatly appreciated. I'm about to give up
My config.plist attached(removed serial info)
Using opencore 0.6.8
Kexts:
AMDRyzenCPUPowerManagement.kext AppleMCEReporterDisabler.kext LucyRTL8125Ethernet.kext USBPorts.kext WhateverGreen.kext
AppleALC.kext Lilu.kext NVMeFix.kext VirtualSMC.kext
Drivers:
OpenRuntime.efi, Hfsplus.efi
Hardware breakdown:
CPU: AMD 5950x
GPU: AMD 6900XT Reference Card( finally supported on 11.4)
Motherboard: Asus X570 Crosshair Dark Hero
Hard drive: 2x WD SN850 2TB
Ram: Crucial ballstix 128gb 3600
Cooler: Noctua Nh-D15
Case: Phanteks 500A
Kexts:
Drivers:
Hardware breakdown:
CPU: AMD 5950x
Case: Phanteks 500A
