Thanks will try thatTry disabling Whatevergreen.
im finding the 6800xt works a lot better without it for now.![]()
Well colour is move vibrant , but lost my DP and had to swap to HDMITry disabling Whatevergreen.
Strange , but all is working , faster on CL and a little slower on Metal according to geekbenchThat’s strange as I thought the nitro used the same layout as the reference card so the dp port should work fine.
I have tested a hand full of 6800 and 6800xt models and makes and they all worked via dp with weg disabled.
I didn’t try a nitro as we dont have one on the shelve over here.
Swap the last two patches. Disable Algrey’s PAT patch and enable mine. It’ll increase GPU performance but HDMI/DP audio will suffer.Me Too OpenCL is very slow
It must be the apple drivers as using windows I get 173566 under CL . But using that patch on Big sur I get as high as 191000 on Metal.Yes, the score went from 80,000 to 110,000
Show your EFI, please.3900X with X570 Master V1.1 . 6800XT Nitro + SE. 16 GB 4400 DDR4
Was a bit of a drama getting it to update , in the end built a new 0.6.8 debug stripped right back and got there.
OpenCL is very slow , but the metal is impressive
Have to added the pikera argument in NVRAAM.Show your EFI, please.
i have a black screen with my EFI...
Under Windows, I got 180,000 in OpenCL, and under Bigsur, I also got 190,000 in Metal, but only 110,000 in OpenCLIt must be the apple drivers as using windows I get 173566 under CL . But using that patch on Big sur I get as high as 191000 on Metal.
So its really good . Will have to see when I add water cooling to the Nitro +
Used a different config. The graphics have started. But now there is another problem. The installer loads data on the ssd and when booting from ssd the kernel does not start when choosing to boot from this ssd, as I understand it ... I do not understand why.Have to added the pikera argument in NVRAAM.
What is your setup to make sure it will work
if you use my plist remember to add a serial number etc
