3900X 570X Master 6800XT Nitro + SE Big Sur 11.4 Beta
slehc84
3900X with X570 Master V1.1 . 6800XT Nitro + SE. 16 GB 4400 DDR4
Was a bit of a drama getting it to update , in the end built a new 0.6.8 debug stripped right back and got there.
OpenCL is very slow , but the metal is impressive
AudioGod
Try disabling Whatevergreen.
im finding the 6800xt works a lot better without it for now. 👍
slehc84
slehc84
Well colour is move vibrant , but lost my DP and had to swap to HDMI
AudioGod
That’s strange as I thought the nitro used the same layout as the reference card so the dp port should work fine.
I have tested a hand full of 6800 and 6800xt models and makes and they all worked via dp with weg disabled.
I didn’t try a nitro as we dont have one on the shelve over here.
slehc84
Strange , but all is working , faster on CL and a little slower on Metal according to geekbench
scofield2021
Me Too OpenCL is very slow
Swap the last two patches. Disable Algrey’s PAT patch and enable mine. It’ll increase GPU performance but HDMI/DP audio will suffer.
scofield2021
Yes, the score went from 80,000 to 110,000
slehc84
It must be the apple drivers as using windows I get 173566 under CL . But using that patch on Big sur I get as high as 191000 on Metal.
So its really good . Will have to see when I add water cooling to the Nitro +
slehc84
Show your EFI, please.
i have a black screen with my EFI...
Have to added the pikera argument in NVRAAM.
What is your setup to make sure it will work
if you use my plist remember to add a serial number etc
  • Config.plist
scofield2021
Under Windows, I got 180,000 in OpenCL, and under Bigsur, I also got 190,000 in Metal, but only 110,000 in OpenCL
mwdisaster
Used a different config. The graphics have started. But now there is another problem. The installer loads data on the ssd and when booting from ssd the kernel does not start when choosing to boot from this ssd, as I understand it ... I do not understand why.
  • opencore-2021-05-02-141933.txt
mwdisaster
Everything worked out! everything is working)
