Strange mouse input
silvergraphs
9
Buenos Aires, Argentina
Ryzen 7 5700X
As I describe it in the title, I have a very different entry in macOS than in Windows (obviously) but, can it be solved in any way? It is a bit annoying, since the mouse is moving at a slow speed and slowly it is as if the sensitivity was raised without touching anything, all this every time the mouse is moved. Will it have to do with some kind of feature with macOS? I use a Razer DeathAdder Elite
I think You have too much driver files like PS2USBA etc. try delete them just leve basics
Where do I find those files?
In your EFI folder (EFI->OC->Drivers)
You should have something like this :
and now delete unnecessary files. For my .cfg it looks like this :
And now try install macOS again, now yours problem should be solved. :)
Reactions: silvergraphs
This is my config. do you think there is something wrong with it for mouse input?
