Ryzen 9 3950x | Gigabyte X570 Master | Radeon VII | OC 0.5.8
Ch4n4i
Hi Hackintoshers
This is my flawless workinh Hackintosh (Opencore 0.5.8 ndk fork ):
OS X : Catalina 10.5.5 Beta 4
Cpu : Ryzen 9 3950x
Gpu: XFX Radeon VII
Memory: 16GB DDR4
Motherboard : Gigabyte Aorus x570 master
Cooler : Corsair H150i Pro
Case : Cosmos C700M
SSD /HDD : Corsair ForceLE 240GB + HDD 4TB
Screen : Samsung Cf791 3440x1440 100HZ
Working : Everything except : Wifi/BT & Sleep
The Geekbench result seems a little low for a 3950, that’s about what I get with my 3900.
Looks like you dont have XMP enabled in the bios, not sure what memory you have but looks like its running at 2400mhz..
What did you need to get your board running? Did you need to fix KASLR?
Did you try running a basic BT Adapter (even a 4.0) and see if it just works as plug & play? I saw on YouTube that for some people it works like that
I would agree the geekbench scores seem slow for the 3950X - here are my scores from this week.
Reactions: AMDPUSH
Yep, that would also downclock the infinity fabric and hurt performance, if you don't have RAM that can reach 3200 you should at least re-configure the factor to get the infinity fabric up to 3200.
Hi, would you be gentle to share your build please ?
OS X : Catalina 10.15.2
Cpu : Ryzen 9 3950x 16-core
Gpu: Sapphire 5700XT 8GB
Memory: G.SKILL 64GB 4X16 D4 3600 TRZ RGB
Motherboard : GIGABYTE X570 AORUS MASTER ATX
Cooler : NZXT KRAKEN M22 LIQUID COOLER
Case : NZXT H510 ELITE BLK TG RGB
SSD /HDD : Samsung SSD 860 QVO 2TB
Screen : Monoprice IIIP - 32inch 4k IPS
Reactions: AMDPUSH
Did you encounter the problem that the monitor has no output signal or grey screen when waking up from sleep or booting?
I always turn of Sleep in preferences actually so I don't know if there's an issue there. I always just turn my screensaver on.
No issue during boot at all. I did see an issue where the computer didn't like me starting up with one of the HDMI ports on the graphics card so I used the other one.
I did have to add agdpmod=pikara to my boot args to get it to boot properly. I have read this is a temporary work around.
Hi, thank you !
Does the Samsung SSD 860 QVO 2TB performing well ?
