    Votes: 12 75.0%
    Votes: 2 12.5%
    Votes: 2 12.5%
  • Total voters
    16
  • Poll closed .
downloaded, this installer is too slow because im using macos in virtual machine
Patients Buddy, It will be worth it if it works. (y)
I forgot to swap the ethernet kext to the one you need to use for high Sierra, Replace the kext with the correct one or ethernet won't work. As you already know its a simple copy and replace with no touching the config.plist needed.
I don't know why, but the macos virtual machine is crushed, now I'm trying again for the third time to build the installer with BuildmacOSInstallApp.command
Assign more memory and cores to the virtual box bud.
Why don't you do it in windows instead? It's no harder really.
And I would highly advise doing it the way Dortonia say to create a USB Installer.
Amico dei pazienti, ne varrà la pena se funziona. (y)
Ho dimenticato di scambiare il kext ethernet con quello che devi usare per High Sierra, sostituisci il kext con quello corretto o ethernet non funzionerà. Come già sai, è una semplice copia e sostituisci senza toccare il file config.plist necessario.
yesyes, ty mate. as soon as I create the usb and add the file I'll let you know.
on windows from an error and I don't know how to fix it, the important thing is to get to the finish line even if it takes a little more time at least it gets there
it doesn't make me create usb. I am attaching a photo, I tried with 2 usb a 2.0 and a 3.0 Error.PNG
If you can’t do it via a virtual machine then your only other option would be to do it in windows.
I create usb installers all the time via windows or macOS using the same method as you are trying to do and I’ve never had a problem doing it.
i used the efi you gave me without touching anything just adding the new kexts, it gives the same error as before.
I’m all out of ideas for now. I have no idea why this is happening to you.
What revision bios are you using?
It’s because they have updated to F32, it’s not on all the boards yet as they had a problem with there server but it’s available to download. F31 works fine anyway
could it be that putting "load optimized default" loads something wrong in the BIOS? I don't know what to think, if I have a faulty motherboard or something ... I hope you get some ideas
If you want to try reflashing your bios then you can download F32 Release from here.
Im testing F32 with my memory and PBO tuned settings on the X570 Pro right now and it seems fine so far.
Reactions: Toslim
Hi mate,
Just wanted to thanks you for the work you put in to the EFI and supporting everyone.
My setup is a X570 Pro, 3950x and Nitro Vega 64... Had some issues with a black screen until I removed the boot argument agdpmod=pikera which seems obvious but I have had previous builds where that didn't hurt.
Probs try upgrading the Bios later from F11 but first things first time to get rid of the minging desktop background.
Cheers for this it is much appreciated.
  • Love
Reactions: AudioGod
Hi mate,
Thanks for the kind words buddy, It’s much appreciated :)
Do update your bios yes but wait until Revision F32 goes live on there webpage.
Can you tell me if there is a way to change the resolution of the picker screen 4k is to small for me.
Thanks
Se vuoi provare a eseguire il reflash del tuo BIOS, puoi scaricare la versione F32 da qui.
[URL unfurl = "true"] https://www.tweaktownforum.com/foru...dors/gigabyte/28656-gigabyte-latest-beta-bios [/ URL]
Sto testando F32 con la mia memoria e le impostazioni ottimizzate per PBO sull'X570 Pro in questo momento e finora sembra
Is secure the source?it is not better to wait for the official one on the gigabyte site?
Great will keep an on that, I have a 6900xt that is being wasted in Windows until the macOS Drivers come out so will do a bios update if that ever gets support.
Thanks again.
Thanks
Go into the Config.plist and under UEFI -> Output -> Resolution change it from Max and set the resolution you want.
Example - Output = 1920x1080@32
Its from gigabyte themselves, this is where they post the beta BiOS for Users to try, If you look who posts them you can see he’s from gigabyte. F32 is not beta it’s release. 👍
Reactions: svan71
Your the best man, thanks again. I have been using a GT 710 and things have been fine. I would love to use a ASUS STRIX R7 370 I have but it requires a few edits that are above my pay grade :( Could you help me with that?
