Solved Fresh 0.6.4 BigSur - Constant Reboot after OSX Install (RESOLVED)
Cavalicious
26:768 00:512 AAPL: #[EB|SB:p] 0x1
26:806 00:038 AAPL: #[EB|SB:SBGMFNS] j137ap.im4m
26:845 00:038 AAPL: #[EB|SB:MF] \\macOS Install Data\\Locked Files\\BootKernelExtensions.kc.j137ap.im4m
26:883 00:038 AAPL: #[EB.LD.LF|IN] 0 1 <"\\macOS Install Data\\Locked Files\\BootKernelExtensions.kc.j137ap.im4m"> <"0">
26:922 00:039 AAPL: #[EB.LD.OFS|OPEN!] Err(0xE) <"\\macOS Install Data\\Locked Files\\BootKernelExtensions.kc.j137ap.im4m">
26:961 00:038 AAPL: #[EB.SB.VK|!] Err(0xE) <- EB.LD.LF
27:005 00:044 AAPL: #[EB.LD.LKCFFP|!] Err(0x1A) <- EB.SB.SBVK
27:047 00:041 AAPL: #[EB|CS:SRBM] secure-boot
27:085 00:038 AAPL: #[EB|FWFM] 0x00000000FFFFFF7F
27:124 00:038 AAPL: #[EB|FWFT] 0x00000000FDAFF066
27:167 00:043 AAPL: #[EB|B:RB]
27:205 00:037 AAPL: #[EB|WL] 0 0 0x01 0x41 24 0x0E
27:244 00:038 AAPL: #[EB|REBOOT] 1
27:282 00:038 AAPL: #[EB|LOG:RESET:RECOVERY] 2021-01-03T05:41:08
USB boots fine to BigSur installation. After installation, it reboots and gets the error above. I've done a number of installs, including Catalina upgrade to BigSur, but thisis the first time i've ran into this issue.
  • Config.plist
You are trying to boot an update partition.
Gigamaxx
How can I get it out of the loop. The OpenCore menu never comes up.
Turn off the power switch. Hold down to start
button 10 sec. to degauss the caps.
Use reset CMOS switch if you have it.
turn power switch back on and start holding the delete key to enter bios (other key may need to be used, F12, Esc. Etc.
in bios check the boot 1 option set to the USB.
Reboot
Cavalicious
  1. Used CMOS button on back
  2. re-configured BIOS
  3. OpenCore Menu now shows up
  4. Three Options: macInstaller, Install MacOSx (External), setup
  5. Chose 2nd option (Install MacOSX (external))
  6. Re-installed Big Sur (~10min left)
  7. Sytem Reboots
  8. Same 3 options like before, this time let default (macInstaller) execute
  9. Same Boot Loop like before.
