BCM94360CS2 is 1.5cm higher than the intel one and BCM94360NG.
I made a hole on the plastic cover so it would go through the surface a little bit.
Not as ugly as I thought intially TBH.
Hi Buddy,Hello AudioGod, I am currently running Mojave (Clover) on Ryzen 5 3600 on Gigabyte AORUS X570 Itx, everything works fine, but I am looking to swap the CPU to Ryzen 7 5800x, however I tryied once on my 3600, using my old Cover boot, the latest BIOS(F31q) didn't boot, so then I switch to OC 0.6.4. , under BIOS F10 it booted fine, but once I update to F31q, it failed to boot.
I am wondering if you could tell me what should be done to run the series 5000 on Mojave, on BIOS F31q, if using OC 0.6.4.
Here is my setup:
CPU: Ryzen 7 5800x
Mobo: Gigabyte AORUS X570 Itx (F31q)
Grapgic: Radeon Rx vega 56
And attached is EFI file I am using for OC 0.6.4
Hello buddy, thanks for your quick reply, I tried once used your EFI(without the usb kext), it work with F10(or F11), but once I update to official F31q, it didn’t boot either. Also i swapped the original WiFi card to Broadcom BCM94350ZAE so the Bluetooth and Airdrop works perfectly when on clover. But after I switch to OC, when I used the USB next from your EFI, it won’t boot even under bios F10, the whole OC boot is still new to me since I build the Hackintosh on clover. But the whole process is interesting to me, I am still waiting for the new cpu to come, and I am not in the hurry to fix it, so take your time and maybe we could do some experiment for the rest the forum with similar situation.Again, thank you very much ~Hi Buddy,
im not in front of my Hack at the second but will take a look when I get back home.
In the mean time grab my EFI on page one and try using it as it should be perfect for your build.
Other people with your board are using my EFI with pure success.
If your using the onboard WiFi then there’s also the correct USBMap.kext for you on here if you go back a page and look.
lastly grab the finished bios F31 not beta and use that, it’s not on the gigabyte site yet but you can grab it from here.
X570IAORUSPROWIFI
MediaFire is a simple to use free service that lets you put all your photos, documents, music, and video in a single place so you can access them anywhere and share them everywhere.www.mediafire.com
Did you input your details into the EFI (serial, uuid and mlb)?Hello buddy, thanks for your quick reply, I tried once used your EFI(without the usb kext), it work with F10(or F11), but once I update to official F31q, it didn’t boot either. Also i swapped the original WiFi card to Broadcom BCM94350ZAE so the Bluetooth and Airdrop works perfectly when on clover. But after I switch to OC, when I used the USB next from your EFI, it won’t boot even under bios F10, the whole OC boot is still new to me since I build the Hackintosh on clover. But the whole process is interesting to me, I am still waiting for the new cpu to come, and I am not in the hurry to fix it, so take your time and maybe we could do some experiment for the rest the forum with similar situation.Again, thank you very much ~
a. I did input my detail based on your EFI config.plist, but still, the problem is F31q didn't work while F10(or F11) works.Did you input your details into the EFI (serial, uuid and mlb)?
the new firmware I sent you is the official release of F31, F31q is beta and abit messed up.
do you have RC scripts installed via clover, if you do you need to get rid of it or Oc won’t work.
have you tried putting the EFI onto a Big Sur USB install drive and seeing if you can get to the first page of the installer?
if you can then the problem is within your instal on your drive.
also are you using the settings I have laid out for the bios on page one?
I also saw this tutorial, but when I successfully booted (ryzen5 3600,BIOS F10) after swap the OC EFI, I didn't bother to clean up the old clover, but perheps I should do it, to finish the whole transition.@ck_zheng If you can boot to the first page of the installer via a usb install key then it’s more then likely that you need to clean your boot drive of all clover clutter.
follow this little guide to do just that.
OpenCore-Install-Guide/clover-conversion at master · dortania/OpenCore-Install-Guide
Repo for the OpenCore Install Guide. Contribute to dortania/OpenCore-Install-Guide development by creating an account on GitHub.github.com
Update your bios from F31q to F31, F31q is full of bugs that have been fixed in F31 official release.I also saw this tutorial, but when I successfully booted (ryzen5 3600,BIOS F10) after swap the OC EFI, I didn't bother to clean up the old clover, but perheps I should do it, to finish the whole transition.
I will update my situation here once plug in the new cpu, but I also suspect that I would be able to even boot in the system.
Thank you and I will that you know.
There's no reason that 5000 series wouldn't work on 10.13.x onwards. They use the current Ryzen patches as is and as long as you've got the fixed OC 0.6.4 it'll work.
Thanks AudioGod and @Shaneee, it's great to know that 5000series should work on these similar AMD parts and Mojave, I have my bootable USB prepared, will update the siuation here once I try it out.That’s what I thought too, Thank you buddy
@ck_zheng Just to add, The 5000 and 3000 series use the same setup via OpenCore, no changes needed quirk or setup wise.
The only real rule is to make sure your using F30 or newer bios wise.
My EFI is setup for a 3000 or 5000 series using bios revision F30 or higher out of the box With absolutely no changes needed other then the ones I’ve told you to do.
Good Luck Buddy.Thanks AudioGod and @Shaneee, it's great to know that 5000series should work on these similar AMD parts and Mojave, I have my bootable USB prepared, will update the siuation here once I try it out.
Thanks all for the help~
Hiya,Hi AudioGod,
I am trying to use your EFI package with my System: X570 Aorus Master, 5950x, RX560
I have only a windows pc and tried to create a USB stick with the official OC guide - now I have the com.apple.recovery.boot and EFI folder (yours) on my stick.
Changed the relevant settings in BIOS (i guess) - but I just cant get the first page of the OC menu...
Is it maybe needed to make a usb installer stick with MacOS?
Hiya,Hello!
I've been using your EFI for a while, my Ryzen 9 5950X system is very stable, everything works including sleep/wake. Thank you!
Now I would like to use your ACPI USB patch SSDT-XHC and USBMap, I use X570 Aorus Master motherboard.
Should I change them as the USB layout will probably be a little different.
I also use Gigabyte RGB controller with liquidctl that uses internal USB. I exchanged the original Intel BT/Wifi card with BCM94360NG and it's used in the M2 socket now.
Your looking at the io wrong brother.One note.
I noticed that your SSDT-HC file under XHC has twice the ports 1PRT, 2PRT, 3PRT, 4PRT.
When I look at my original DSDT dump file then there is no double under this controller.
Is that correct?
