Success Big Sur 11.1 OC 0.6.1 --> Big Sur 11.0.1 it's BETTER !
Natale7
23
After Catalina, here is Big Sur ! add MLB, SystemSerialNumber and SystemUUID
Return to Big Sur 11.0.1 because all the programs are running !
@Natale7 I was able to get my Gigabyte Aorus X570 Pro + 5950X working with your EFI! Thank you, everything works, but Audio is making noises, cracking. Did you also had that?
Reactions: Natale7
no it's impeccable, you use your screen for sound?
Set your PCIe Generation to 3 (from Auto/4) in your bios to see if that helps with the crackling.
