Ryzen 3
sukpmp
Hi, I'm new to this forum. Is there a guide to specs that are known to work? Is a Ryzen 3 build possible?
i'm on ryzen 5600x just make sure you are using opencore 0.64 and you should be good.
I run High Sierra on my Ryzen 5950x. I use it for audio production and it's great.
I never encountered stability issues for the moment. I think it depends on what you do.
Only some weird graphical issues (lag when resizing windows) but probably due to bad Nvidia web drivers (I still use my gtx960).
I also use OpenCore 0.6.4 with latest AMD patch.
Thanks. I've heard a few stories about stability - how is it for you?
running fine for a couple weeks now, i have no figured out sleep yet...
