I haven't Etehrnet Post install X570 TUF Plus with Realtek L8200A Lan
exxtevao
I can't connect to the ethernet post install Catalina 10.15.7. All kexts are updated ans I'm using Opencore 0.6.3. My MoBo Lan is Realtek L8200A.
MoBo: Asus Tuf X570 Gaming Plus
CPU: Ryzen 7 3800x
Gpu: Rx 580 8GB Gigabyte
and bla bla bla
Someone can help me?
Gigamaxx
CPU: Ryzen 7 3800x
and bla bla bla
See this. #54112
Gigamaxx
I saw that, but only works for 1 PERSON, WORKS ONLY FOR HER!
Did you place the kext in OC/Kexts and then add to the kernel/Add section of plist?
exxtevao
Yes. All of my kexts and config are OK, using Realtek L8111 but don't connect
Gigamaxx
Use Hackintool and post a pic of the device ID. Hackintool/PCIe tab.
Gigamaxx
Gigamaxx
exxtevao
  • info.txt
  • pcidevices.plist
Gigamaxx
I'm using!
I t says 8111, can you post a pic of the Hackintool like this?
I'm lookin g for the device ID and Vendor etc. its on the left side of the pic, the dump doesn't have that info.
exxtevao
exxtevao
Its showing the 8111, 8168, 8411 IDs Realtek8111.kext should work.
Did the Lucy kext work?
Lucy stuck on Screen Logo, don't boot
exxtevao
exxtevao
