Disabling SIP on beta 9 and above
pi2in3
i cant disable SIP using both 670000 and FF0F0000 value for csr-active-config which works fine on Beta4.
i atached config.plist here.
I had to add csr-active-config to Delete as shown here.
Either add it to Delete, or do an NVRAM reset before booting up with the new entry. OC won't override existing NVRAM keys otherwise.
pi2in3
i always do an NVRAM reset, i did after add it to Delete but no success.
could u check my config file?
Have you tried E7030000 ?
Deleted member 473
put in config SIP value to all 0
then from recovery
csrutil clear
csrutil disable
it should work in this way
