Shaneee's RyzenPro - 5600X, RX 480
11
1,405
212
33
Scotland
amd-osx.com
Ryzen 5 5600X
What works? Everything so far...
Any questions feel free to ask.
Geekbench Results:
CPU :- https://browser.geekbench.com/v5/cpu/6994253
OpenCL :- https://browser.geekbench.com/v5/compute/2559653
Metal :- https://browser.geekbench.com/v5/compute/2559661
Cinebench:
Multicore: 11110
Adobe apps work ?
Any luck with parallels ?
This is my current setup.
  • Installed Operating Systems: Catalina 10.15.4 - Windows 10 Pro
  • CPU: Ryzen 5 3600
  • Motherboard: MSI MPG X570 Gaming Plus
  • RAM: 16GB DDR4 3200MHz
  • Graphics: ASUS ROG Strix RX560
  • HDD: 960 EVO 500GB - MX500 250GB - 640GB WDC - 500GB WDC
  • LAN: RTL8111
  • Sound: Onboard/HDMI
  • Other: USB Bluetooth - USB Wireless Mouse and Keyboard
  • Bootloader: OpenCore
What works? Easier to say what doesn't work...
  • Sleep
Similar config. I had sleep working by deactivating serial port in the bios. You should give it a go
Currently running macOS Big Sur as my daily now. No major issues so far.
Reactions: Aluveitie
Very happy to hear that !
And adobe premiere work flawlessly ?
Hi, any update about the sleep?
Also your EFI would be very welcome or at least your SSDT / kext list. thanks!
+1
I have the same motherboard so would love to know if I did things properly. It runs great right now, the only issue I have is sleep (I swear it was working at one point of time) and long boot time.. (25+ sec).
Nice to hear it can run Big sur btw..
Edit : Also want to thank Shaneee for all the work he's done for the community! Gracias Amigo!
Can i have your EFI folder ?
Then you won't learn anything. Read through the Dortania guide and you'll learn all you need to know.
Reactions: slavezeo and tomnic
I am stuck on the below .
ASSERT [OpenCore] /Users/travis/build/acidanthera/OpenCorePkg/UDK/MdePkg/Library/BaseIoLibIntrinsic/IoLibGcc.c(152): (Port & 3) == 0
Using opencore 0.6.2.
Amd FX 4100, legacy settings.
gigabyte ga-78lmt s2
No errors is sanity checker
had been trying for a week stuck on 2 min remaining followed Daytona debugging guide also no luck for me :(
Work Big Sur with 15h_16h processors and patches?
@Shaneee one help how to change processor name intel i5 to amd ryzen 5
My processor is ryzen 5 3600x
Currently running big sur 11.0.1
Please reply, thanks
@Shaneee can you help my problem?
same mobo
First post updated. New CPU, GPU and updated GeekBench scores :D
