Solved: Stuck at IOConsoleUsers: gIOScreenLockState 3, hs 0, bs 0, now 0, sm 0x0 with GT710 (GK208)
proton
Since the last weekend, I have been attempting to install Catalina 10.15.7, using OpenCore 0.6.2. I properly followed Dortania guide, did sanity check of the config.plist, applied all the available BIOS settings (as much permitted in my bios), but I ended up with this error -
28:081 00:017 AAPL: [EB|`B:WFDW] Err(0xE), 0 @ LocHB 71B4903C-14EC-42C4-BDC6-CE1449930E49
28:098 00:016 AAPL: [EB|#LOG:DT] 2020-10-28T13:56:22
28:115 00:017 AAPL: [EB|#LOG:EXITBS:START] 2020-10-28T13:56:22
I tried troubleshooting, booting from different USB ports, and even used the additional kexts used by similar builds. Though most of the log has changed, I am still reaching the same point. Can anyone please help me? I am almost at the verge of abandoning it, given the amount of time I have spent on this. I am attaching my latest log. The system details is in my signature. Please let me know if you need any additional info.
  • opencore-2020-10-28-135554.txt
sdljljdwa
i also have the same problem, ive tried so many different things and it still doesnt work, im still trying to fix it though and if i get anything ill post here
sdljljdwa
i turned DevirtualiseMmio to false and was able to boot into mac os im not sure itll work for you as well but worth a try
proton
It is set to false on mine. I don't understand what is OCSMC. Below I have marked the places where I see Err, I don't know if those are the items that are causing the problem or something else.
10:562 00:050 AAPL: [EB|`CS:CSKSD] Err(0xE) @ GV 8D63D4FE-BD3C-4AAD-881D-86FD974BC1DF:boot-info-payload
10:682 00:019 AAPL: [EB|`WL:pWLFNV] Err(0xE) @ GV wake-failure
10:702 00:020 AAPL: [EB|`WL:DT] Err(0xE) @ WL:pWLFNV
10:743 00:020 AAPL: [EB|`WL:DT] Err(0xE) @ WL:pWLFRTC
10:825 00:021 AAPL: [EB|`LD:OFS] Err(0xE) @ OPEN (System\\Library\\PrelinkedKernels\\immutablekernel.development)
16:643 00:020 OCSMC: SmcReadValue Key 4D535463 Size 1
16:663 00:020 OCSMC: SmcReadValue Key 4D534163 Size 2
16:684 00:020 AAPL: [EB|`B:WFDW] Err(0xE), 0 @ LocHB 71B4903C-14EC-42C4-BDC6-CE1449930E49
16:704 00:020 AAPL: [EB|#LOG:DT] 2020-10-29T15:07:38
16:725 00:020 AAPL: [EB|#LOG:EXITBS:START] 2020-10-29T15:07:38
proton
I figured that I was looking at the wrong place for the issue. The posts above are from the log that was saved to EFI root. When I recorded the verbose (literally on my mobile), I saw that the display is shutting down after IOConsoleUsers: gIOScreenLockState 3, hs 0, bs 0, now 0, sm 0x0
Upon checking the Troubleshooting page, I tried all the steps that seemed relevant for my GT 710.
shikigva=40
agdpmod=vit9696
Changed the SMBIOS to iMac14,2
Tried to find a way to force PCIe to 3.0, but the card only supports PCIe 2.0. Can this be the reason?
My monitor is connected directly (no adapters) to the HDMI port, should I try any other port?
Has anyone been successful with GT 710 paired with Ryzen 5 3600x on a B450?
Check what variant your GT 710 is. You can check this with GPU-Z on Windows. Mine uses GK208 and works even in Big Sur.
proton
Mine too is same, only for a tad lower ASIC rating. It runs at PCIe 2 x8, right? Did you use any additional boot arguments? I am planning to do a DDU clean install. Shall post if I get any success with it.
sileshn
I have the same graphics card and a ryzen 2400g cpu. Currently running BigSur 11.0.1 beta
proton
Tried DDU clean.
Booted again, same (attached)
Clean install of NVIDIA GeForce Graphics Drivers 457.09 WHQL.
Booted again, same!
proton
DDU isn't going to help as that deals with Windows. I didn't do anything special when I tested it. Just latest Whatevergreen.kext and iMacPro1,1 SMBios.
proton
It was getting listed on my BIOS. So I just thought if cleaning it out will help. Obviously it didn't. I could install it by disabling nvidia driver in boot arguments. Will nVidia patch work for this? I mean now it only says 8MB vram.
Also, do WiFi dongles work with Catalina. The one I am using doesn't have drivers for Catalina, but supports till Sierra.
proton
Everything that I need is now working. I only want to patch my video card somehow. Is there an alternate way? Should I use Legacy Nvidia patching mentioned in the guide?
Is there any other work around?
proton
proton
Is there any other patch which I can try? I couldn't find anything working for me that is listed in WEG Geforce FAQs.
I tried spoofing GPU, but there was a panic ACPI Error:...AE_ALREADY_EXISTS
While I was spoofing it, I decided to take a look at my DSDT and see how it is defined there. I observed that in my DSDT had Method (_DSM, 4, Serialized) while the SSDT-GPU-SPOOF has it as Method (_DSM, 4, NotSerialized)
Can this be the reason for the IOConsoleUsers: gIOScreenLockState 3, hs 0, bs 0, now 0, sm 0x0 error?
What SMBios are you using?
proton
proton
I used the latest OC0.6.3 and all the latest releases of kexts with it. Still the same result. I also tried to spoof GPU but I think it doesn't work with new GPUs, as I was getting errors while creating NVCAP.
I am really out of ideas, @Shaneee, can I send you my DSDT, EFI and any other files that may be needed for you to have a look. I saw on Discord channel too that there are people struggling with the same issue.
@proton Sure upload the EFI you are currently trying to use.
proton
I have also attached my DSDT _SB/PCI0/GPP8 is my graphics I think.
  • opencore-2020-11-04-001742.txt
  • DSDT.aml.zip
