Same result @ShaneeeIt is OC 0.6.3 with all the latest kexts released with it. I saw the only so many slides on the log, so I thought that may be the problem. I will remove it.
I am directly connecting to HDMI, no adapter or anything.What connector are you using? macOS has issues with the VGA and sometimes DVI, this includes adapters.
Hi I have had success with a similar setup, I cannot boot with the latest Kernel Patches the problem is patch 32, when i replace -I figured that I was looking at the wrong place for the issue. The posts above are from the log that was saved to EFI root. When I recorded the verbose (literally on my mobile), I saw that the display is shutting down afterIOConsoleUsers: gIOScreenLockState 3, hs 0, bs 0, now 0, sm 0x0
Upon checking the Troubleshooting page, I tried all the steps that seemed relevant for my GT 710.
shikigva=40
agdpmod=vit9696
Changed the SMBIOS to iMac14,2
Tried to find a way to force PCIe to 3.0, but the card only supports PCIe 2.0. Can this be the reason?
My monitor is connected directly (no adapters) to the HDMI port, should I try any other port?
Has anyone been successful with GT 710 paired with Ryzen 5 3600x on a B450?
YES!!!!Hi I have had success with a similar setup, I cannot boot with the latest Kernel Patches the problem is patch 32, when i replace -
uXcCAAC4BgYGBroGBgYGDzAPCQ==
With this :
uXcCAAC4BgEHALoGAQcADx9AAA==
Using PlistEdit Pro it boot every time with no problems.
npci=0x2000
arg in your config under boot-args.Hi, can you share EFI folder? My 710 not work. Thanks.YES!!!!
Thank you so much!!!
This absolutely worked!
