Runs Sequoia and Tahoe, latest versions of both OS's.
He tried but didnt work maybe i can try after the work.If you read through post #30 from the link above, you will see that the Tahoe kext has been limited to work with 3 x specific cards. So to get your Mediatek Bluetooth module working you need to do the following:
1. You need to edit the Tahoe kext and add your own idVendor/idProduct entries to the kext, using Hex Fiend.
2. You need to add a Bluetooth specific boot argument -bluetoothmediatek
3. You need to add the Bluetooth NVRAM entries shown below (bluetoothInternalControllerInfo and bluetoothExternalDongleFailed) to your config.plist.
4. You need to ensure you have the USB port serving the Bluetooth module active and set as 'Internal' in your USBMap.kext or USBPorts.kext, whichever you are using.
Did you or your friend complete the above process for your Mediatek Bluetooth module?
I’m still new to creating EFI folders and working with kexts, so I’m not very familiar with the process. If I manage to get my EFI folder ready, I’ll share it with you&people.Also, could you please check the Bluetooth settings and make the necessary changes to the EFI folder I send you, then share the updated version with me?Care to post a copy of your Working EFI folder, with the Serial Number redacted/deleted from the config.plist. It would help others with the same board.
Yes, I could provide the kext and update the EFI/config.plist to work with the Mediatek Bluetooth. But I would need the vendor ID and Product ID for the Bluetooth module to do that. Can you provide these pieces of information along with a copy of the working EFI folder?
Do you have a working USB configuration/kext for macOS Tahoe?
These are my efi and device report.I hope they help for my bluetooth and other people who needs Asus Tuf Gaming x670e-wifi mobo.Honestly i have no idea about that.Need to check them at night.
I'll try it and will write the result later.Ty for your helpBu revize edilmiş BueToolFixup_Mediatek_SRS_Tahoe.kext dosyası artık Mediatek Bluetooth cihazınızın (0E8D) Geliştirici Kimliğini içeriyor. Bu bilgi aslında kext'in Sequoia sürümünde mevcuttu ancak kext Tahoe'ya geçiş yapıldığında değiştirildi. Bunun nedeni, kext'in 3 cihazla sınırlı olması ve sizin cihazınızın listede yer almaması olabilir diye tahmin ediyorum.
Yenilenmiş Tahoe kext dosyası, gerekli Bluetooth config.plist düzenlemeleriyle birlikte ekli /EFI/OC/Kexts klasörüne eklendi.
Siz veya arkadaşınızın Hack cihazınızda bazı işlemler yapması gerekiyor. Aşağıda bağlantısı verilen 35 numaralı gönderiye bakın. 3. maddeden itibarenki maddeler sizin dikkatinizi gerektiriyor, bunlar benim yapamayacağım işlemler. Bu işlemler doğru şekilde tamamlanmadığı takdirde Bluetooth cihazınız çalışmayacaktır.
Bakalım bu yöntem sisteminizde işe yarayacak mı.
USB yapılandırmanız/kext'inizle ilgili olarak, EFI'nizde Bluetooth cihazının Hack'inizde doğru şekilde yapılandırılmasını sağlamak için gerekli olan özel bir kext bulunmamaktadır. Kurulumunuzda özel bir UTBMap.kext olsa bile, macOS Tahoe'da işe yaramaz, çünkü USBToolBox.kext ve USB bağlantı noktası keşif aracı Tahoe ile çalışacak şekilde güncellenmemiştir.
UTBDefault.kext, birden fazla USB denetleyicisi içeren AMD AM5 sistemlerinde işe yaramaz. Kext yalnızca tek bir USB denetleyicisindeki (XHC1) portları etkinleştirmeye çalışır, bu nedenle USB portlarınızın çoğu, hatta tamamı, macOS'un uygun gördüğü şekilde etkinleştirilir. Bu nedenle, portların birçoğunun çalışmaması veya çalıştıklarında yanlış hızda çalışması sizi şaşırtmasın.
Sisteminiz için özel bir USBMap.kext veya USBPorts.kext dosyası olmadan Bluetooth cihazının çalışması olası değildir. Çalışsa bile bağlantı kopmaları, aksaklıklar ve diğer sorunlarla karşılaşmanız muhtemeldir.
