Tahoe not working on Ryzen 5 3500u
rakismac32
AMD Ryzen 5 PRO 3500U w/ Radeon Vega Mobile Gfx
So currently i have a successful install of macOS Ventura 13.7.8 on my ThinkPad T495s with these specifications:
CPU: AMD Ryzen 5 PRO 3500U w/ Radeon Vega Mobile Gfx
RAM: 16GB DDR4 2400MHz
SSD: 256GB NVMe
Wifi card: Intel Wireless AC 9260
iGPU: AMD Radeon Vega 8 Graphics
My current working efi build is mostly 'inspired' by this repo: https://github.com/PersistentCloud/Thinkpad-T495-Hackintosh
but when i try to upgrade to tahoe i simply get a kernel panic after reboot and trying to get into the installer assistant phase
Things i've tried:
Updating nootedred to a nightly build 0.9.0
Regenerating smbios to macbookpro 15,2
Any ideas to what i should change further to get tahoe working?
Your config is a bit of a mess if I'm honest, for a start you put the patches in the wrong place!. I've never owned a Laptop hackintosh so I wouldn't be the best person to ask, but if you already have a successful installation of Ventura I suggest looking at the structure of that config to get a better idea of what you did wrong.
Thanks for the response! it's my first time ever getting a reply in a forum site, fun fact.
Anyway, if the misplaced patches you're referring to is patches.plist file in EFI/OC, i remember it's a leftover from AMD_Vanilla patch which the contents i have copied to the config.plist in Kernel -> Patch, so i don't think it's being used by the bootloader.
However, i feel like my config is missing patches specifically required in Tahoe or Sequoia, since this same config can still boot Ventura, unlike other efi build i tried which won't even boot Ventura.
