Need assistance adapting EFI for macOS Tahoe (Ryzen 9 7950X3D + RX 6900 XT)
hinkin
62
AMD Ryzon 9 7950X3D
Hi everyone,
I’ve been trying for several days to get my EFI configuration working for macOS Tahoe on my system, but I haven’t had any success so far.
Hardware Configuration​
  • CPU: AMD Ryzen 9 7950X3D
  • Motherboard: Gigabyte X870 AORUS ELITE WIFI7
  • RAM: 64GB DDR5 5000MHz
  • GPU: AMD Radeon RX 6900 XT 16GB
  • Network: Realtek RTL8125B
  • Wi-Fi/Bluetooth: Fenvi T919 PCIe WLAN Card
I currently have a fully working EFI for macOS Sequoia, but I need assistance in adapting or fixing it so that it can properly install and run macOS Tahoe on this setup.
I’m sharing my current EFI folder for anyone interested in helping improve or create a Tahoe-compatible version.
Any help or suggestions would be greatly appreciated.
Thank you in advance!
1. I only have Radeon GPU on board. 2. I have disable iGPU. 3, I have tested with and without whatevergreen. 4, I am using a recovery installer. 5. I am using the ethernet at 2.5gb.
neither A or B
Always Hang on apple?
Do you see after installer choice in the bootloader some text lines output before the "apple"?
Your Fenvi is on a pcie slot or you have mounted in motherboard place unmounting original wifi?
if you have on a PCIe slot, have you disabled internal wifi/BT from bios?
1. Always Apple with boot line only going halfway. 2. I dont see any text lines before the Apple. 3. Not using wifi only ethernet wired.
@PYLZNER with my last config you should see after the boot menu a bunch of text lines (usually called verbose output)
if you dont see this output, maybe you are booting from a different EFI
Reactions: Edhawk
I just put in the first config u sent, I do see text before installer choice, no Apple, shows the prohibited symbol.
let start better :)
post the efi you use to reach that apple hang
in this EFI i would try to add -v bootarg you missed in your config and then enabling the quirk to skip for now a proper MMIO whitelist
if you can put also in your signature your exact system you are trying to setp (hardware and OS)
it will more simple to remember for aged people as me, your hardware ;)
Asus Rog Strix X870A
AMD Ryzen 9 9950X3D
Radeon rx 6800 XT
G.SKILL Trident Z5 Neo RGB Series DDR5
ASUS Rog Ryujin III 360 ARGB
Samsung Pro 990 2TB
Samsung 980 500MB
Attempting to install Tahoe via Hackintosh
